Page 1 of 8 1 2 3 ... LastLast
Results 1 to 12 of 90
Thread: EI Standard for Aviation fuel handling sharing.
    Dear all,
    As my title of this topic. I need some EI standards for my research in aviation fuel handling. The list is at
    [link Point to another website Only the registered members can access] I have some already (EI1530, 1543, 1529, 1540, 1541, 1542, 1550, 1581, 1583, 1590, 1596, 1597) but after googled for quite long time I still lacking of the others.
    Please share me if you have or if anyone need my existing one, I'm happy to share.
    Re: EI Standard for Aviation fuel handling sharing.
    May I suggest you post the ones that you do have and make a list of the ones that you need.
    Question Re: EI Standard for Aviation fuel handling sharing.
    Ok. Here is the list:
    1. What I need:
    EI 1598 Design, functional requirements and laboratory testing protocols for electronic sensors to monitor free water and/or particulate matter in aviation fuel
    EI Research Report: Electrostatic discharges in two inch aviation fuel filter monitors. Phase 2: Properties needed to control discharges
    EI 1599 Laboratory tests and minimum performance levels for aviation fuel dirt defence filters
    EI Research Report: Electrostatic discharges in two-inch fuel filter monitors
    EI Research Report: Investigation into the effects of lubricity additives on the performance of filter/water separators
    EI 1582 Specification for similarity for EI 1581 aviation jet fuel filter/separators
    Multi-product pipelines: minimum criteria to determine additive acceptability
    EI Research Report: Review of methods of bonding a hydrant dispenser (servicer) to an aircraft for refuelling
    EI 1584 Four-inch hydrant system components and arrangements
    EI 1570 Handbook on electronic sensors for the detection of particulate matter and/or free water during aircraft refuelling
    EI 1560: Recommended practice for the operation, inspection, maintenance and commissioning of aviation fuel hydrant systems and hydrant system extensions
    EI 1585 Guidance in the cleaning of aviation fuel hydrant systems at airports
    Research report: A qualitative assessment of electrostatic risks in jet fuel handling and distribution
    2. What I have:
    EI 1529 Aviation fuelling hose and hose assemblies
    EI/JIG Standard 1530 Quality assurance requirements for the manufacture, storage and distribution of aviation fuel to airports
    EI 1540 Design, construction, commissioning, maintenance and testing of aviation fuelling facilities
    EI 1541 Performance requirements for protective coating systems used in aviation fuel storage tanks and piping
    EI 1542 Identification markings for dedicated aviation fuel manufacturing and distribution facilities, airport storage and mobile fuelling equipment
    EI 1550 Handbook on equipment used for the maintenance and delivery of clean aviation fuel
    EI 1581 Specification and qualification procedures for aviation jet fuel filter/separators
    EI 1583 Laboratory tests and minimum performance levels for aviation fuel filter monitors
    EI 1590 Specifications and qualification procedures for aviation fuel microfilters
    EI 1596 Design and construction of aviation fuel filter vessels
    EI 1597 Procedures for overwing fuelling to ensure delivery of the correct fuel grade to an aircraft
    Please share me what you have other than mine and tell me if you need any of the above.
    Many thanks.
    Attached Files Attached Files
    By the word "post", I mean upload and post a download link of the ones that you have. I will look to see if I have any of your missing.
    Ok. I'm trying to upload it. This is the first time I use this forum, some of files are to big to upload as attachment.
    Continue part 3. The rest are two big (the smallest is 5MB already) so we have to think about another means for sharing.
    Thanks my brother
    I have API/IP SPEC 1582:
  14. #11
    trungtt, I hope you can upload the two large files to dropbox.com or any other similar page. Best Regards
  16. #12
    Thanks a lot!
  1. API 1581 - Specifications for aviation jet fuel filter/separators
    By vjr0512 in forum Mechanical Engineering
    Last Post: 06-07-2019, 04:56 AM
  2. Replies: 7
    Last Post: 02-05-2017, 10:48 AM
  3. Replies: 1
    Last Post: 03-05-2015, 03:06 PM
  4. Reuest API Aviation standard
    By tromix in forum Mechanical Engineering
    Last Post: 10-28-2012, 01:46 PM
