Results 1 to 9 of 9
Thread: Swps aws b2. 1-1-234 and aws b2. 1-1-235
  1. Swps aws b2. 1-1-234 and aws b2. 1-1-235
    Does enyone have this two swps, please share it.
    Aws b2. 1-1-234
    and
    aws b2. 1-1-235
  3. Re: Swps aws b2. 1-1-234 and aws b2. 1-1-235
  6. Re: Swps aws b2. 1-1-234 and aws b2. 1-1-235
    thanks a lot
    Thank you.
  9. Re: Swps aws b2. 1-1-234 and aws b2. 1-1-235
    Hello
    Please i need aws B2.1-1-022-1994
    Thanks,,,,,,,,,
    AWS B2.1-1-022-94R WPS for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 1-1/2 inch Thick, E6010 (Vertical Uphill) Followed by E7018, As-Welded or PWHT Condition
    Attached Files Attached Files
    Has anyone got any of these? (non scanned versions)
    AWS B2.1-8-213
    AWS B2.1-1-027
    AWS B2.1-1-201
    AWS B2.1-1-209
    You state non-scanned, but that is how AWS released many of these.
    I only have... as an original pdf
    AWS B2.1-1-201-96 R2007 SWPS for Shielded Metal Arc Welding of Carbon Steel (M-1/P-1/S-1, Group 1 or 2), 1/8 through 3/4 inch Thick, E6010 (Vertical Uphill) Followed by E7018 (Vertical Uphill), As-Welded Condition, Primarily Pipe Applications
  1. AWS-B2.1-22-015:2002- SWPS by GTAW for Aluminum
    By cpchonburi in forum Mechanical Engineering
    Last Post: 03-06-2024, 10:31 PM
  2. AWS Standard Welding Procedure Specification (SWPS)
    By alimojtabaei in forum Mechanical Engineering
    Last Post: 07-02-2018, 04:45 PM
  3. Aws (swps)- b series
    Last Post: 10-23-2013, 07:38 AM
