Page 1 of 23 1 2 3 11 ... LastLast
Results 1 to 12 of 271
Thread: UL Standards Needed
  1. UL Standards Needed
    Dear Friends,
    I need the following UL Standards:
    UL 1 Flexible Metal Conduit
    UL 4 Armored Cable
    UL 8 Foam Fire Extinguishers
    UL 9 Fire Tests of Window Assemblies
    UL 10B Fire Tests of Door Assemblies
    UL 10C Positive Pressure Fire Tests of Door Assemblies
    UL 38 Manually Actuated Signaling Boxes for Use with Fire-Protective Signaling Systems
    UL 83 Thermoplastic-Insulated Wires and Cables
    UL 94 Tests for Flammability of Plastic Materials for Parts in Devices and Appliances
    UL 96A Installation Requirements for Lightning Protection Systems
    UL 125 Flow Control Valves for Anhydrous Ammonia and LP-Gas
    UL 132 Safety Relief Valves for Anhydrous Ammonia and LP-Gas
    UL 142 Steel Aboveground Tanks for Flammable and Combustible Liquids
    UL 154 Carbon-Dioxide Fire Extinguishers
    UL 199 Automatic Sprinklers for Fire-Protection Service
    UL 299 Dry Chemical Fire Extinguishers
    UL 217 Single and Multiple Station Smoke Detectors
    UL 219 Lined Fire Hose for Interior Standpipes
    UL 231 Power Outlets
    UL 260 Standard for Dry Pipe and Deluge Valves for Fire-Protection Service
    UL 262 Gate Valves for Fire-Protection Service
    UL 268 Smoke Detectors for Fire Protective Signaling Systems
    UL 268A Smoke Detectors for Duct Application
    UL 312 Check Valves for Fire-Protection Service
    UL 325 Door, Drapery, Gate, Louver, and Window Operators and Systems
    UL 331 Strainers for Flammable Fluids and Anhydrous Ammonia
    UL 340 Tests for Comparative Flammability of Liquids
    UL 393 Indicating Pressure Gauges for Fire-Protection Service
    UL 401 Portable Spray Hose Nozzles for Fire-Protection Service
    UL 404 Gauges, Indicating Pressure, for Compressed Gas Service
    UL 437 Key Locks
    UL 448 Standard for Pumps for Fire-Protection Service
    UL 467 Grounding and Bonding Equipment
    UL 508A Industrial Control Panels
    UL 525 Flame Arresters
    UL 539 Single and Multiple Station Heat Detectors
    UL 674 Standard for Electric Motors and Generators for Use in Division 1 Hazardous (Classified) Locations
    UL 698A Industrial Control Panels Relating to Hazardous (Classified) Locations
    UL 711 Fire Extinguishers, Rating and Fire Testing
    UL 719 Nonmetallic-Sheathed Cables
    UL 727 Oil-Fired Cental Furnaces
    UL 778 Motor Operated Water Pumps
    UL 789 Indicator Posts for Fire-Protection Service
    UL 844 Electric Lighting Fixtures for Use in Hazardous (Classified) Locations
    UL 864 Control Units and Accessories for Fire Alarm Systems
    UL 913 Intrinsically Safe Apparatus
    UL 1002 Electrically Operated Valves for Use in Hazardous (Classified) Locations
    UL 1040 Fire Test of Insulated Wall Construction
    UL 1058 Halogenated Agent Extinguishing System Units
    UL 1072 Medium-Voltage Power Cables
    UL 1091 Butterfly Valves for Fire-Protection Service
    UL 1203 Explosion-Proof and Dust-Ignition Electrical Equipment for Use in Hazardous (Classified) Locations
    UL 1468 Standard for Direct Acting Pressure Reducing and Pressure Restricting Valves
    UL 1481 Power Supplies for Fire Protective Signaling Systems
    UL 1486 Quick Opening Divices for Dry Pipe Valves for Fire-Protection Service
    UL 1685 Vertical-Tray Fire-Propagation and Smoke-Release Test for Electrical and Optical-Fiber Cables
    UL 1709 Standard for Rapid Rise Fire Tests of Protection Materials for Structural Steel
    UL 1711 Amplifiers for Fire Protective Signaling Systems
    UL 1730 Smoke Detector Monitors
    UL 1739 Pilot-Operated Pressure-Control Valves for Fire-Protection Service
    UL 1778 Uninterruptible Power Systems
    UL 1803 Factory Follow-Up on Third Party Certified Portable Fire Extinguishers
    UL 2034 Single and Multiple Station Carbon Monoxide Detectors
    UL 2111 Overheating Protection for Motors
    UL 2227 Standard For Safety For Overfilling Prevention Devices
    UL 2250 Instrumentation Tray Cable
    UL 2351 Spray Nozzles for Fire-Protection Service
    UL 5085-3 Low Voltage Transformers - Part 3: Class 2 and Class 3 Transformers
    UL 60079-5 Electrical Apparatus for Explosive Gas Atmospheres - Part 5: Powder Filling 'q'
    UL 60079-6 Electrical Apparatus for Explosive Gas Atmospheres - Part 6: Oil-Immersion 'o'
    UL 60079-7 Electrical Apparatus for Explosive Gas Atmospheres - Part 7: Increased Safety "e"
    UL 60079-15 Electrical Apparatus for Explosive Gas Atmospheres - Part 15: Electrical Apparatus with Type of Protection 'n'
    UL 60745-1 Hand-Held Motor-Operated Electric Tools - Safety - Part 1: General Requirements
    Anyone having these standards could you please upload them.
    Thanks very much.
  3. Good post. I appreciate it.
    Many thanks to ur post. I love it.
  5. svz sfdb dgn
    HI Guniawala,
    UL 83-2001 Thermoplastic Insulated Wires and Cables.pdf 0.945 MB
    UL 142 - 1998-for steel aboveground tank for flammable liquid.pdf 5.801 MB
    UL 1709-2007 Rapid Rise Fire Tests of Protection Materials for Structural Steell.pdf 1.249 MB
    UL 1730-2007 Standard for Smoke Detector Monitors and Accessories.pdf 0.496 MB
    UL 1739-2007 Standard for Pilot-Operated Pressure-Control Valves for Fire-Protection Service.pdf 0.208 MB
    UL 1778 2005 Uninterruptible Power Systems.pdf 0.765 MB
    UL 2034-2007 Standard for Single and Multiple Station Carbon Monoxide Alarms.pdf 1.029 MB
    That’s all I have for this moment.
    I Think the following UL Standard are similar with IEC.
    If you accept IEC please let me know
    HI Guniawala,
  9. Some more UL Standards
    Dear Achmad Nur Eddin,
    Thank you very much for uploading UL standards. There are some more standards in my library. I request other members to please upload if you have UL standards. In the end we will all have the complete set.
    UL 4 - Armored Cable.pdf
    UL 444 - Communication Cables
    UL 467 - Grounding and Bonding Equipment
    UL 674 - Electric Motors and Generators for Use in Division 1 Hazardous (Classified) Locations
    UL 698A - Industrial Control Panels Relating to Hazardous (Classified) Locations
    UL 711 - Rating and Fire Testing of Fire Extinguishers
    UL 823 - Electric Heaters For Use In Hazardous (Classified) Locations
    UL 844 - Luminaires for Use in Hazardous (Classified) Locations
    UL 877 - Circuit-Breaker Enclosures for Use in Hazardous Locations
    UL 886 - Outlet Boxes and Fittings for Use in Hazardous (Classified) Locations
    UL 894 - Switches For Use In Hazardous (Classified) Locations
    UL 913 - Intrinsically Safe Apparatus for Use in Class I, II, and III, Division 1 Locations
    UL 1424 - Cables for Power-Limited Fire-Alarm Circuits
    Thank you for your sharing !!!!
    I like to download your file, but it is shown in the rapidshare the following note :
    1st try with the file armored
    ERROR
    You want to download the following file:
    This file can only be downloaded by becoming a Premium member
    There are no more download slots available for free users right now. If you don't want to become a premium member, you might want to try again late
    2nd try with file grounding
    ERROR
    There are no more download slots available for free users right now. If you don't want to become a premium member, you might want to try again later.
    I'm not premium member.
    But could you please upload again in another website such as ifile
    Thank you
  11. Sorry, I am new in uploading. Here is another link
    Thanks Friend
    Sep 2008
    Planet Earth
    Hi Gunaiwala and Achmad,
    Keep up the good work, I will try to upload some too
  14. #11
    Achmad Nur Eddin and Guniawala, thanks for sharing
  16. #12
    1. UL 1-2007 Standard for Flexible Metal Conduit.pdf 542.23 KB
    2 UL 5A-2008 Nonmetallic Surface Raceways and Fittings.pdf 933.08 KB
    3 UL 5B-2009 Strut-Type Channel Raceways and Fittings.pdf 634.5 KB
    4 UL 5C-2007 Surface Raceways and Fittings for Use with Data, Signal, and Control Circuits.pdf 500.3 KB
    5. UL 6-2004 Electrical rigid metal conduit-steel.pdf 687.53 KB
    6 UL 10B-2008 Standard for Fire Tests of Door Assemblies.pdf 549.8 KB
    7. UL 10C-2009 Positive Pressure Fire Tests of Door Assemblies.pdf 0.655 MB
    8. UL 48-2004 Standard for Electric Signs.pdf 0.714 MB
    9. UL 96-2005 Standard for Lightning Protection Components.pdf 0.592 MB
    10 UL 96A-2007 Installation Requirements for Lightning Protection Systems.pdf 1.095 MB
    That’s all I have for today
  1. Standards needed
    By panthere0rose in forum Mechanical Engineering
    Last Post: 05-22-2015, 12:38 AM
  2. Iso standards needed
    By Onoma Epwnymo in forum Laboratory Measurements
    Last Post: 03-30-2013, 01:02 PM
  3. standards needed
    By mmanous13 in forum Mechanical Engineering
    Last Post: 09-04-2012, 03:18 AM
  4. Standards needed
    Last Post: 04-17-2012, 08:34 PM
  5. Jpi standards needed
    By setak in forum Materials Science &Corrosion
    Last Post: 08-06-2011, 12:15 AM
