Results 1 to 9 of 9
Thread: Weldolet Design
  1. Weldolet Design
    Dear All
    im looking for formulas to calculate a Weldolet based on ASME code.
    Anybody can help?
    Or maybe better if there is any spreadsheet for this calculation.
    Thank You
    Re: Weldolet Design
    Hi
    Based on ASME B31.3 if you are using standard factory-made weldolet (or other fitting) per ASME B16.9 , there is no need more calculation ,
  5. Re: Weldolet Design
    hi there
    thank you, but if the weldolet is not standard?
  6. Re: Weldolet Design
    Then you can resort to para 304.7.2. Weldolets are per MSS SP-97
    Quote Originally Posted by VanniDiCarlo View Post
    hi there
    The weldolet, sockolet and many other fitting, are registered products of Bonney Forge, therefore, you will not find it in any standard code.
    Sent from my SM-G900H using Tapatalk
  9. Re: Weldolet Design
    Quote Originally Posted by barrerav View Post
    Incorrect. See my previous reply. Weldolets are per MSS SP 97, not ASME B16.9. The new ASME B31.3 does detail welding requirements for olets.
    The MSS are practices standardized of manufacturers and are established only by reference in other documents such as specifications, in this case, the designer and owner of this products is Bonney Forge. You can review the weldolet specifications visiting BonneyForge.com.
  11. Re: Weldolet Design
    For example if you go the the link
    Asme B31.3 - Par. 304.3.3 Reinforcement of Welded Branch Connections.
  1. Replies: 4
    Last Post: 10-23-2014, 07:23 AM
  2. Replies: 17
    Last Post: 03-11-2014, 05:32 AM
  3. Replies: 0
    Last Post: 06-27-2013, 07:25 PM
  4. Replies: 0
    Last Post: 05-11-2013, 02:23 PM
  5. Replies: 2
    Last Post: 06-01-2010, 12:22 PM
