Results 1 to 10 of 10
Thread: MSS SP-87 Anyone?
    MSS SP-87 Anyone?
    Hi all,
    Does anyone have MSS SP-87-2011 Factory-Made Butt-Welding Fittings for Class I Nuclear Piping Applications? I have searched far and wide but cannot seem to find a spare copy anywhere. Even an older version would do, but I prefer the newest if possible.
    Re: MSS SP-87 Anyone?
    Deleted, cause Marty Thompson attached in next.
    We have not seen the 2011, but for others
    Direct link...
    MSS SP-87-1991 R1996 Factory-Made Butt-Welding Fittings for Class I Nuclear Piping Applications
  6. Re: MSS SP-87 Anyone?
    Quote Originally Posted by kgy0001 View Post
    Hi all,
    plz refer to ipi.ir/standard
  7. Re: MSS SP-87 Anyone?
    Nothing changed in 2011. Here is
    selmagis,
    for the updated file in post below
    Thank you Selmagis, Marty Thompson, and Rezaeima. Since receiving your files I have compared MSS SP-87 to SP-43, SP-75, and ASME B16.9 in regards to fitting dimensions only. The only differences among the four are as follows:
    1. Limitations on cap wall thickness for determination of overall end-to-end dimension. MSS SP-87 gives almost identical values as ASME B16.9 except to an extra sigfig. Interestingly, ASME B16.9 (2012) has a different end-to-end dimension for NPS 1/2, but I believe that to be a typo even though an errata has not been issued on its behalf.
    2. Center-to-End for NPS 3/4 on long radius elbow tables. MSS SP-87 is the only one stating a different dimension here, but a footnote gives option to use the dimension given on the other specifications. I consider it likely this oddball size will be dropped in future revisions.
    If MSS SP-87 has changed anything, from its Reaffirmed 1996 to Reinstated 2011 editions, I would expect the fourth paragraph of page one not to mention conflict resolution with ASME B.16.28 (it was retired in 2002).
    Thanks again, you have been tremendously helpful.
    Here is
