Thread: deIsopentanizer and deIsohexanizer oerating conditions
  1. deIsopentanizer and deIsohexanizer oerating conditions
    Hi,
    I'm currently working on conceptual design stage of an Light Naphtha Isomerization unit. This unit includes deIsopentanizer and deIsohexanizer for component separation and recycle, to continue this simulation study we are short on normal operating data of these two column:
    1. Column Pressure
    2. Bottom Temerature
    3. Top Temperature
    4. No of trays
    5. Feed tray location
    I will be very grateful if someone can provide above mentioned data for both the columns.
    Thanks.
    Re: deIsopentanizer and deIsohexanizer oerating conditions
    Hi;
    A normal deisohexanizer column (DIH) has a normal operating conditions Top/bottom temperature = 72/132 ºC, with a P=4 kg/cm2g. The number of trays are around 116 (depending of tray efficiency). Feed tray location is aprox in tray 45/46.
    I fyou have more doubts, indicate me.
    Hi;
    A normal deisohexanizer column (DIH) has a normal operating conditions Top/bottom temperature = 72/132 &#186;C, with a P=4 kg/cm2g. The number of trays are around 116 (depending of tray efficiency). Feed tray location is aprox in tray 45/46.
  6. Re: deIsopentanizer and deIsohexanizer oerating conditions
    Thank you very much for this information. I think this much data will be sufficient for my simulation study.
    Can you help me with the deIsopentanizer?
  1. FIDIC Conditions of Contract for Construction
    By Sanchezj20 in forum Planning & Project Management
    Last Post: 10-10-2013, 07:14 PM
  2. need for EN-10163 Standard For Surface Conditions
    By axabrt in forum Mechanical Engineering
    Last Post: 06-04-2013, 03:33 PM
  3. CO2 Supercritical conditions
    By evolutionb in forum Oil And Gas Process
    Last Post: 12-31-2011, 04:13 AM
