Results 1 to 12 of 12
Thread: ASHRAE Standard 62, Current Edition
    I'm looking for ASHREA 62 [2001 edition]. The version I have is missing pages 11 to 13
    D
    Re: ASHRAE Standard 62, Current Edition
    Ok...so it seems that 2004 62 was split up into 62.1 and 62.2 and that the current editions are 2013...any help would be appreciated.
    ASHRAE Standard 62.1-2013 - Ventilation for Acceptable Indoor Air Quality
    ASHRAE Standard 62.2-2013 -Ventilation and Acceptable Indoor Air Quality in Low-Rise Residential Buildings
    D
    D
    I have this one only...
    ANSI/ASHRAE Standard 62.1-2004 Ventilation for Acceptable Indoor Air Quality 2005 62.1 User’s Manual
    in 4 parts, download all, change file type to .b1
    hi. ANSI/ASHRAE Standard 62.1 2013:
    Attached Files Attached Files
    ANSI/ASHRAE Standard 62.2 2013:
    Thanks mohamad3010,
    here are your files cleaned up.
    **Corrected the file name
    thanks marty for cleaning files.
    You guy's are Fantastic...
    D
    Marty,
    FYI...When I extracted the file it extracted as "ANSI" without a file extension. When I did it again, it warned me that I was going to over right the file. When I noticed the name it was using, it had a ":" in the file name. Thinking this was causing the problem with a lack of file extension, I used the "Rename" option and simply saved it as "ASHREA.pdf", and it worked fine. I've since renamed it properly...
    D
  14. #11
    Very good! Thanks
  16. #12
    Thank you..
  1. Ashrae standard 120
    By supernova1387 in forum Mechanical Engineering
    Last Post: 05-29-2014, 07:18 PM
  2. Ansi ashrae iesa standard
    By Achmad Nur Eddin in forum Mechanical Engineering
    Last Post: 11-27-2011, 11:26 PM
  3. ANSI/ASHRAE Standard 52.2-2007
    By linhtruong in forum Petrochemical
    Last Post: 04-25-2011, 01:51 PM
  4. ANSI/ASHRAE Standard 52.2
    Last Post: 04-25-2011, 01:48 PM
  5. ASHRAE Standard 34, 2007 Edition
    By DM2 in forum Safety And Environment
    Last Post: 12-21-2009, 08:55 PM
