All dear bros,
Today i am posting again a request for few Latest version of Standards.....please help..i need all these standard urgently and free....
i am posting here the list of standard what i required please if possible provide me all..
API STANDARD
Sr. No. TITLE DESCRIPTION REQUIRED EDITION
1 API -591 PROCESS VALVE QUALIFICATION PROCEDURE. 2014
2 API-594 CHECK VALVE FLANGED, LUG, WAFER AND BUTTWELDING 2010
3 API-598 VALVES INSPECTION AND TESTING. 2009
4 API-599 METAL PLUG VALVES - FLANGED, THREADED & WEDING ENDS 2013
5 API-607 TESTING OF VALVES-FIRE TYPE TESTING REQUIREMENTS. 2010
6 API-608 METAL BALL VALVES FLANGED,THREADED & BUTTWELDING ENDS 2012
7 API-609 LUG & WAFER - TYPE BUTTERFLY VALVES 2012
8 API-600 STEEL GATE VALVES 13 TH EDITION
9 API-6D SPECIFICATION FOR PIPELINE VALVES. 24 TH EDITION 2014
ASME STANDARD
1 ASTM VOLUME 01.01 IRON & STELL PRODUCTS STEEL PIPING , TUBING , FITTTINGS 2015
2 ASTM VOLUME 01.02 IRON &STEEL PRODUCTS FERROUS CASTING FERROALLOYS SECTION-1 2015
3 ASTM VOLUME 01.03 IRON AND STEEL PRODUCTS. STEEL- PLATE ,STEEL , SHEET, STRIP WIRE, STAINLESS STEEL BARS. 2015
4 ASTM VOLUME 01.05 IRON &STEEL PRODUCTS STEEL BARS ,FORGING BEARING ,CHAIN SPRING SECTION-1 2015
5 ASTM VOLUME.01.08 IRON AND STEEL PRODUCTS 'FASTENERS' 2015
6 ASTM VOLUME.02.01 NONFERROUS METAL PRODUCTS . COPPER & COPPER ALLOYS 2015
7 ASTM VOLUME 03.01 METAL TEST METHOD & ANALAYATICAL PRODUCES METAL MECHANICAL TESTING ELVATED &
LOW TEMPRATURE TEST METALAGRAPY SECTION -3 2015
8 ASME SECTION -II PART D PROPERTIES' 2001 ASME BOILER & PRESSUR VESSEL CODE MATERIAL 2013
9 ASME SECTION -VIII DIVISION- 3 1998 ASME BOILER & PRESSURE VESSELES CODE DIVISION -3 ALTERNATIVE
RULES FOR HIGH PRESSURE VESSELS RULES OF CONSTRUCTION OF PRESSURE VESSELS 2013
10 ASME SECTION IX BOILER & PRESSURE VESSEL CODE AN INTERNATIONAL CODE 2013
11 ASME B 16.5 PIPE FLANGE & FLANGED FITTING PIPE NPS1/2" THROUGH 24" 2013
12 ASME B 16.10 FACE TO FACE & END TO END DIMENSION OF VALVES. 2009
13 ASME B 16.11 FORGED FITTINGS SOCKET WELDING AND THREADED 2011
14 ASME B 16.20 METTALIC GASKET FOR PIPE FLANGES RING JOINT SPIRAL WOUND & 2012
15 ASME B 16.21 NONMETTALIC FLAT GASKET FOR PIPE FLANGES 2011
16 ASME B 16.25 BUTTWELDING ENDS 2012
17 ASME B 16.34 VALVE , FLANGED ,THREADING & WELDING ENDS, 2013
18 ASME B 16.47 LARGE DIAMETER STEE FLANGES NPS 26 THROUGH NPS 60 2011
19 ASME- B.1-1 UNIFIED INCH SCREW THREADS (UN & UNR THREAD FROM ) 2003
20 ASME B 18.2.1 SQUARE & HEX BOLTS & SCREWS(INCH SEARIES) 2012
21 ASME B 18.8.2 TAPER PINS, DOWELPINS, STRAIGHT PINS, GROOVED PINS & SPRING PINS (INCH SERIES) 2010
22 ASME B 18.2.2 SQUARE & HEX NUTS (INCH SEARIES) 2010
23 ASME - B- 31-3 PROCESS PIPING 2012
24 ASME - B- 31-4 PIPELINES TRANSPORTATION SYSTEMS FOR LIQUID HYDROCARBON & OTHER LIQUIDS 2012
25 ASME - G-93 STANDARD PRACTICE FOR CLEANING ,METHODS & CLEANLESS LEVEL FOR MATERIAL &
EQUIPMENT IN OXYGEN ENRICHED ENVIRONMENTS 2011
ISO STANDARD
1 ISO-5208 INDUSTRIAL VALVES PRESSURE TESTING OF VALVE 2008
NACE STANDARD
1 NACE-MR0175/ISO 15156-1 PETROLEUM & NATURAL GAS INDUSTRIES MATERIAL FOR USE IN H2S-
CONTAINING ENVIRONMENT IN OI & GAS PRODUCTION PART-1 GENERAL PRINCIPAL FOR SELECTION OF *****INGG RESISTANT 2014
2 NACE-MR0175/ISO 15156-2 PETROLEUM & NATURAL GAS INDUSTRIES MATERIAL FOR USE IN H2S-
CONTAINING ENVIRONMENT IN OI & GAS PRODUCTION PART-2 *****ING RESISTANT CARBON &1000 ALLOY STEEL & THE USE OF CAST IRONS 2014
3 NACE-MR0175/ISO 15156-3 PETROLEUM & NATURAL GAS INDUSTRIES MATERIAL FOR IN H2S
CONTAINING ENVIROMENT IN OIL GAS PRODUCTION. PART3.*****ING RESISTANT CRAS (CORROSION RESISTANT ALLOYS & OTHER ALLOYS 2014
4 NACE-MR0103 ITEM NO.21305 STANARD MATERIAL REQUIREMENT MATERIAL RESISTANT TO
SULFIDED STRESS *****ING IN CORROSIVE PETROLEUM RETINING ENVIRONMENTS 2012
I will be very thankful to all of you please help me ..i need these standard urgently...
thank you in advance ...
