Dear All,
I've problems with the selection of fiscal (custody transfer) gas metering system of the natural gas pipeline with 20% CO2. Firstly I selected to use Ultrasonic Flow Meter (UFM) for pipeline 12, 16 and 18 inches. But information from one Vendor (Daniel) required minimum pressures which are above the operating pressure range (min - max). The Vendor recommended to use the UFM which the operating pressure range above the minimum pressure required.
Can anyone recommend/suggest the type of meters for the above mentioned conditions? For the sizes 16 and 18 inches, can I use orifice gas meter?
Thank you in advance for your reply.
Nutcha
