Thread: welding_pipeline_handbook
  1. welding_pipeline_handbook
    Hi friends
    Welding Pipeline Handbook
    This book covers all aspects of welding Process
    TABLE OF CONTENTS
    Joint details
    Joint types
    Electrode positioning angles
    Pipe classification
    Consumption of electrodes
    ASME / EN positions
    THE MANUAL METAL ARC PROCESS
    General information
    Filler materials
    Pipeweld cellulosic electrodes
    Basic electrodes
    Basic electrodes
    Cellulosic electrodes - Technical dfata
    WELDING TECHNIQUES AND OPERATIVE PRACTICES
    General information
    Pipe welding in vertical down (downhill) with cellulosic electrodes 1 - Preparation and tacking
    2 - Joint in 5G/PG position
    3 - Joint in 6G/H-L045 position
    Welding of pipes in vertical up (uphill) with mixed cellolosic/basic technique 1 - Preparation and tacking
    2 - Joint in 5G/PF position
    3 - Joint in 2G/PC position
    4 - Jioint in 6G/H-L045 position
    DEFECTS: CAUSES AND REMEDIES
    AUTOMATIC PIPE WELDING
    General information
    Filler materials
    Welding techniques and operational practices
    Examples of WPS
    Comparison between three welding methods
    Defects and remedies
    Here is the link
    Sasikumar
    Problems of links provided for downloading
    Dear Brother Mohammed Assalamo Alaikum Wa Rahmatullah Wa Barakatuhu& recently past Eid ul Fitr Mabrook,
    It has been quite sometime that I logged on since any of the links,if clicked produced garbage computer language without any downloading at all
    that indicated as if your sharing support services are in-operative or stopped to function.
    I tried quite a few time from my office& home PC's but results same.
    Any guiding info on the issue! Please?
    Best Regards
    Qalander
  5. I downloaded and found the link working ! thanks
    Thank you sasirkumar. The link is working.
    Cheers
    Thank you very much
    Victor Lachica
