Results 1 to 11 of 11
Thread: Require Information Regarding Sulphur recovery Unit
    Question Require Information Regarding Sulphur recovery Unit
    Dear Member's
    I need a Drawing or a System
    which can help me to understand
    Steam & Condensate System on Sulphur
    Degassing vessel (with Sulphur Jacketed Lines Jump overs)
    in Sulphur Recovery Unit
    My problem is ...!!
    How can i reduce so many tapping on main Steam & Condensate header
    coz here with me in my Degassing vessel there are so many Steam & Condensate (3/4" / 0.75") nozzles kept on it and also i have to supply steam in all jacketed line
    Assuming Quick Response from All Members......!!!!
    Note:- If any Member have Picture of Sulphur recovery plant
    Please upload it or send me a mail on Netime_Neway@Yahoo.com
    Many Thanks in Advance
    Mukesh D
    Keep Smiling
    What is your real problem?
    The number of steam and condensate lines or the number of nozzles on the top of the degassing vessel?
  5. i can't understand your problems!!
    i hope... will got the answer!!!!
    sorry i don't know how to explain my prob.
    do u have some sort of drawing or standard which can show me the
    routing of steam & condensate lines on degassing vessel
    coz in my case we have around 42-45 steam inlet & out let nozzles & the size of nozzles are 3/4"
    please Help me
    if u understand my probleum
    mukesh d
  7. What kind of sulphur recovery process is it? see the vol4. of campbel books and tell me, to understand better your problem.
    Its Basically a Coal Gas Treatment plant
    Oxy Claus is the process for sulphur recovery
    Mukesh D
    Where is that Book i m not able to find it
    will u please give me some
    Link or location where i have to find that book
    Mukesh D
  11. Here is, 4 volumes of campbel books, see 4th book, there is the claus process, may be help you..
    I do not have detail drawings to share, but I guess the way is to provide dry steam by means of jumpovers from the steam jackets of the lines connecting to these nozzles and trapping steam condensate from low points. This apparently is to avoid solidification of sulfur in the nozzles. The title you have given for the post is misleading, this probably should have read "Steam Jacketting for Process Lines" or something to that effect. The arrangement should be similar for any vessel or piping in comparable service. The following link may be of some limited use.
    Please explain your problem.
    Your degassing section seems not a typical SRU refinery application.
    Sulphur degassing is usually downstream the Claus (air or oxy) to remove dissolved H2S.
    By the way your question about the routing of steam and condensate pipes seems to be a piping question more than a process question.
    Normally you get the design of the degassing section together with the Claus unit.
    Sulphur lines shall be fully jacketed for sure. LP Steam is normal - remind pressure shall not be too low or it will result in plugging. Therefore consider steam subheaders shall not have too high pressure drops in order to grant enought pressure (so condensing temperature) above sulphur solidification. Steam traps on condensate side shall be commissioned and controlled to make sure they operate properly.
  14. Dear Buddy, please elaborate your problem in detial, so we may be helpful four you, if you need Process flow diagram of Sulfrur Recovery Unit, it can be provided
  1. Sulfur Recovery Unit
    By talk2hnag in forum Petroleum Refining
    Last Post: 11-10-2016, 09:03 AM
  2. Sulphur recovery and amine treating
    By medis.ram in forum Oil And Gas Process
    Last Post: 10-25-2013, 01:35 PM
  3. condensate recovery unit
    By heno82 in forum Oil And Gas Process
    Last Post: 03-18-2013, 10:08 PM
  4. Condensate Recovery Unit (CRU)
    By ali in forum Oil And Gas Process
    Last Post: 09-10-2011, 12:03 PM
  5. Article: Sulfur Recovery Unit
    By talk2hnag in forum Home Articles
    Last Post: 03-13-2011, 11:00 PM
