Thread: DGA plant simulation
    Hello,
    some weeks ago I had been utilising ProTreat in order to model a 10 years old DGA plant which I am now responsible for (H2S + CO2).
    Although I tried hard to input the correct columns and operating data, "lean loading" did not fit to the plant data, actually ProTreat calculates 3 time more H2S in lean DGA. This has as a consequence the sweet gas spec to be violated as well, I mean in the model.
    Trick: if I add to the "amine stream" some HSS (lets say 2% wt) it seems it fixes this discrepancy between real and simulation data.
    Currently I am considering to send amine sample to a Lab specialised in amines analysis to see if this is the case (personally I do not believe it since DGA reclaimer works pretty hard as well). My question is, since said software is quite "rigid" with no "adjustment" options in order to force the model match the reality (and thats I love it), the "trick" I used with HSS is a good thinking or my model will be not predictive if some parameters change in the future.
    Thank you.
  3. Re: DGA plant simulation
    you are using Protreat?
    can you share Protreat v5.3.1?
    Sorry but I was using this software for an evaluation trial period. I have no licence for this. However I found its results very realistic.
  6. Re: DGA plant simulation
    please share v5.3.1 trial version
    there are people out there who can make it stable
  1. Simulation for Benfield plant
    By alex man in forum Petroleum Club
    Last Post: 03-10-2014, 10:14 PM
  2. Process Plant Simulation
    By himanshu in forum Petrochemical
    Last Post: 10-01-2011, 10:23 PM
  3. Manufacturing Simulation with Plant Simulation and Simtalk
    By Azad in forum General Engineering
    Last Post: 07-19-2011, 04:45 PM
