Aluminium Alloys
2012 | 368 pages | PDF | 35 MB
The book is designed to serve as a guide for future innovations and new developments in aluminium alloys.
Aluminium alloys have undergone a dramatic transformation in areas of extrusion, machining, welding, heat treatment, structural changes, created by ultra fine particles and enhanced corrosion resistance. Hence, these alloys have made rapid gains in European automotive and space industry. These developments have been described by experts in the book with new data and attractive graphics.
The effect of processing parameters, including welding and deep rolling on their performance have been highlighted to alleviate the concerns of manufacturers and designers for new applications. The novel role of aluminum alloys in photovoltaic cells and concentrated solar power has been comprehensively described in the context of corrosion and the aggressive environment to which they may be exposed.
Contents
Preface
Section 1: Properties and Structure of Aluminium Alloys
1 Equal-Channel Angular Pressing and Creep in Ultrafine-Grained Aluminium and Its Alloys
2 Durability and Corrosion of Aluminium and Its Alloys: Overview, Property Space, Techniques and Developments
3 Influence of Structural Parameters on the Resistance on the ***** of Aluminium Alloy
4 Effect of Micro Arc Oxidation Coatings on the Properties of Aluminium Alloys
Section 2: Extrusion, Rolling and Machining
5 Effects of Deep Rolling and Its Modification on Fatigue Performance of Aluminium Alloy AA6110
6 Numerical Modelling in Designing Aluminium Extrusion
7 Linear Friction Based Processing Technologies for Aluminum Alloys: Surfacing, Stir Welding and Stir Channeling
8 Dry, Semi-Dry and Wet Machining of 6061-T6 Aluminium Alloy
9 Global Machinability of Al-Mg-Si Extrusions
Section 3: Heat Treatment and Welding
10 Pure 7000 Alloys: Microstructure, Heat Treatments and Hot Working
11 Mechanical and Metalurgical Properties of Friction Welded Aluminium Joints
12 Elaboration of Al-Mn Alloys by Aluminothermic Reduction of Mn203
13 Aluminium Alloys in Solar Power - Benefits and Limitations
