Thread: Rotor Angel for Transient Stability
    Dear All,
    Please kindly explain about rotor angle and it's relationship with transient power system stability?
    Are the rotor angel 90 degrees and -90 degrees stable? Any standard for this value?
    Re: Rotor Angel for Transient Stability
    Are you talking about this formula?
    P(e) = (E1*E2/X)sin(theta1-theta2)?
    Quote Originally Posted by surgeArrester View Post
    Yes, but i want to now the rotor angle phenomena and relationship with stability phenomena? Can rotor angle values are negative?
    Quote Originally Posted by iam3NG View Post
    Yes, there is a chance that the value will be negative. But the question whether or not stable depends on the generator itself - that's why it is needed to have detailed modelling of generators and its parts (ex. governor). But most cases is that negative is unstable.
    It is incomplete if you talk only about the rotor angle. You should its value based on a reference. Remember that the theta in the formula is a difference between two angles. If E1 has negative angle and E2 is zero (reference) then likely that the power flow is backwards which is unstable.
  1. Replies: 5
    Last Post: 11-24-2015, 02:41 PM
  2. Transient Stability ETAP 7.5
    By sophaholic in forum Electrical & Power Engineering
    Last Post: 10-11-2013, 04:41 AM
