Hello peeps,
We are currently trying to service a wellhead control panel manufactured by PIBER (See attachment) but we are having difficulties locating the manufacturer, I don't know if they don't exist as the name anymore. There are a couple of loose items to be procured to service the WHCP.
Please any useful information will be appreciated. See the items below..
1 Pressure gauge: 0-6000psi ; 2’’dia. Face; ¼’’NPT; panel mounting back connection liquid filled
2 Axelson pneumatic pilot valve 3 port with signal valve ¼’’ NPT or similar/alternative type
3 24Vdc solenoid valve 3-way ¼’’ dia. NPT(ASCO)
4 Diaphragm control pilot with pneumatic actuator actuator (Axelson)
5 High pressure hydraulic filter ½’’ dia. NPT (PARKER)
6 Reset pilot valve pneumatic ¼’’ dia. NPT(Axelson)
7 High pressure Haskel 10,000 psi ¼’’ dia. NPT
8 Sight glass small and big for HP & LP hydraulic tank (penberton)
9 Assorted instrument fittings ¼’’ & ½’’ NPT
10 Pressure gauge: 0-60psi; ½’’ NPT; 6’’ dia. Face; panel mounting back connection
11 Pressure gauge: 0-6,000psi; ½’’ NPT; 6’’ dia. Face; panel mounting back connection
12 Pressure gauge: 0-100psi; ½’’ NPT; 6’’ dia. Face; panel mounting back connection
