Iron ore mill equipment selection, Shanghai Joyal to recommend[link Point to another website Only the registered members can access]
. Iron ore Raymond mill is the experts of Shanghai Joyal after years of painstaking innovative research and development, according to the user's use of the mill and suggestions at Raymond grinding mill is updated based on improvements designed for the majority of domestic and foreign offers users a new type, high efficiency, energy saving iron ore mill equipment. The model uses a trapezoidal face, flexible connection, roll linked pressure boost, etc.
After the rock into the rod grinder barrel, first at the beginning of the cast falls under the impact of the steel bar broken into crumbs, then fall in slide and purging the impact of the steel bar further crushing, grinding effect.It is obvious that if the ground to the required size of shell material can be taken out in a timely manner, then, a crushing phenomenon will be greatly re duced.Otherwise, the material repeatedly suffer from steel grinding, a broken broken again, will generate more powder.Therefore, materials in the barrel staying time is too long, namely suffer from steel bar milling time is too long, also is the main reason that caused a smash. At present, for making sand rod[link Point to another website Only the registered members can access]
is generally for wet around middle discharge type.
Iron ore Raymond Mill Features
1. Excellent crushing effect: Multi-level stepped roller grinding ring design to reduce the rate of decline of the material, extending the rolling time and improve product fineness and yield.
2. Cleverly designed damping: the host and the powder soft joint, shock absorber spring and sealed together to reduce the vibration and noise, and to avoid resonance.
3. Efficient balance spring: the use of leverage through the roller assembly rod and horizontal springs are coupled together, seven of the radial force to avoid the bulk material into the grinding chamber after the spindle and bearing loss and improve the use of life.
4. High density impeller device: fineness unchanged in the case of high-density, high-precision impeller impeller speed than the low-density, reduced air resistance, finished under the same power output increased by 50% or more, fineness better.
5. Energy saving centrifugal induced draft fan: Efficient energy-saving fan impeller, the efficiency ratio improved substantially prismatic blade.
Iron Ore Raymond Mill Working Principle
Iron ore[link Point to another website Only the registered members can access]
breaks large lumps of ore stone into needed feed size, by the bucket elevator to transport materials to the storage silos, and then by the electromagnetic vibrating feeder evenly[link Point to another website Only the registered members can access]
sent to the host's grinding room, enter to the grinding chamber material is shovel blade into the grinding roller and grinding ring to be crushed between the blower blowing air from the shunt plate grinding chamber, the pulverized powder to the analysis chamber, after passing by the speed motor driven gear analysis of the impeller rotation sorting, large particles fall back to the grinding chamber material, re-grinding, qualified fine powder with the airflow into the finished product cyclone powder collector, and air separation, the finished product is discharged from the discharge port. Host course of their work, blade system has played a very important role. Which is located in the bottom roller, roller blade and turn the course of the same material scooped ring toss[link Point to another website Only the registered members can access]
roll formed between the litter layer, a layer of the material generated by the grinding roller rotates outward extrusion pressure of the material crushed, which reached milling purposes.
