Results 1 to 8 of 8
Thread: Asme VIII D1 Spanish
  1. Asme VIII D1 Spanish
    alg&#250;n amigo tiene ASME VIII D1 (Espa&#241;ol) 2004 o posterior para compartir la descarga.
    Muchas gracias.
    some friend has ASME VIII D1 (Spanish) 2004 or later to share the download.
    Thank you very much.
    IS.N2
  3. Re: Asme VIII D1 Spanish
    I also need this standard in Spanish. Someone could share
    Thank.
    Version 2010:
    Version 2010:
  7. Re: Asme VIII D1 Spanish
    Quote Originally Posted by alanchip View Post
    Version 2010:
    Dear Sir, thank you for your attention in response. But I need ASME VIII D1 in Spanish ed. 2004 or higher.
    You have this pattern?
    Caro senhor, muito obrigado por sua atenção em resposta. Mas necessito de ASME VIII D1 em espanhol (Ed. 2004 ou superior). Você tem este padrão??
    Muito Obrigado.
    Estimado señor, gracias por su atención en respuesta. Pero necesito ASME VIII D1 en español (Ed. 2004 o superior). ¿Tiene este patrón ??
    Muchas gracias.
    LINK FALL. Update new link please.
    Por favor tienen esta norma en español, el enlace esta caido. ASME VIII Div.1
  11. Re: Asme VIII D1 Spanish
    El link todavia sirve pero es seccion I.. no es la seccion VIII
    Code:
    http://www.4shared.com/get/IlcDC3eSba/203706211-96881629-Asme-I-2010.html
  1. ASME PTB-3-2013 asme section viii div.2 ,example problem manual
    By lois in forum Mechanical Engineering
    Last Post: 02-25-2025, 01:20 PM
  2. Replies: 1
    Last Post: 07-29-2014, 10:26 PM
  3. ASME 3-2010 PTB-asme section viii div.2, example manual
    By rioca57 in forum Mechanical Engineering
    Last Post: 04-02-2013, 04:27 PM
  4. ASME B31.3 Process Piping... Spanish??
    By egonpret in forum Mechanical Engineering
    Last Post: 12-03-2012, 06:15 PM
  5. ASME PTB-3-2010 asme section viii div.2 ,example problem manual
    By sharmilasu in forum Mechanical Engineering
    Last Post: 04-22-2012, 06:57 AM
