Document
Title Current Issue Previous Issue Next Planned Update
SABP-A-001 Polythionic Acid SCC Mitigation – Materials Selection and Effective Protection of Austenitic Stainless Steels and other Austenitic Alloys 7/31/2005 New 8/1/2010
SABP-A-002 Load Management for Energy Efficiency: Pumps and Compressors 10/26/2005 New 11/1/2006
SABP-A-004 Energy Performance Indices 3/19/2006 New 3/19/2009
SABP-A-005 Quick Energy Assessment Methodology for Energy Efficiency Optimization 12/28/2005 New 1/1/2009
SABP-A-007 Steam Trap Management for Energy Efficiency 4/11/2006 New 4/11/2009
SABP-A-008 Load Management for Energy Efficiency: Heat Transfer Equipment 7/5/2006 New 7/5/2009
SABP-A-009 Pinch Technology for Energy Efficiency Optimization 5/9/2006 New 5/9/2009
SABP-A-011 Energy Conservation Requirements in Saudi Aramco Engineering Standards and Materials Specifications 6/12/2006 New 6/12/2011
SABP-A-012 New Projects Energy Efficiency Optimization Review Methodology 9/10/2006 New 9/10/2011
SABP-A-013 Corrosion Control in Amine Units 4/11/2007 New 4/10/2012
SABP-F-001 Process Heaters Optimizations 2/7/2007 New 2/7/2011
SABP-G-001 Centrifugal Pumps Dynamic Analysis Factory Acceptance Test 1/28/2007 6/30/2004 7/1/2009
SABP-G-002 General Purpose Steam Turbines Dynamic Analysis Factory Acceptance Test 10/31/2004 New 11/1/2009
SABP-G-003 Special Purpose Steam Turbines Dynamic Analysis Factory Acceptance Test 10/31/2004 New 11/1/2009
SABP-G-004 Centrifugal Compressors Dynamic Analysis During Factory Acceptance Test 1/28/2007 10/31/2004 11/1/2009
SABP-G-005 Synchronous Motors Dynamic Analysis Factory Acceptance Test 12/29/2004 New 1/1/2009
SABP-G-006 Induction Motors Dynamic Analysis Factory Acceptance Test 12/29/2004 New 1/1/2010
SABP-G-007 Packaged, Integrally Geared Centrifugal Air Compressor Dynamic Analysis Factory Acceptance Test 3/30/2005 New 4/1/2010
SABP-G-008 Field Reliability Unit Guidelines and Procedures 7/31/2005 New 8/1/2010
SABP-G-009 Preventive Maintenance Optimization Guidelines and Procedures 1/31/2006 New 1/31/2011
SABP-G-010 Guidelines for Surveying Manufacturing Facilities of Rotating Equipment 4/14/2007 New 4/13/2012
SABP-L-001 Wall Thickness Selection of Transportation Pipelines 1/28/2007 New 1/28/2012
SABP-M-006 Wind Loads on Piperacks and Open Frame Structures 5/31/2005 7/31/2002 6/1/2009
SABP-M-007 Steel Piperack Design 11/11/2006 8/31/2002 11/11/2011
SABP-P-001 Guidelines for the Condition Assessment of Large Electrical Generators 5/31/2006 New 5/31/2009
SABP-P-002 Selection and Design of Battery Monitoring System 6/5/2006 New 6/5/2011
SABP-P-003 Adjustable Frequency Drives – Selection and Application 6/30/2006 New 6/30/2011
SABP-P-004 Survey Technical Assessment of Transformer Plants 10/28/2006 New 10/28/2011
SABP-P-005 Transformer Factory Acceptance Tests 10/28/2006 New 10/28/2011
SABP-P-006 Synchronous Generators and Associated Control Equipment Datasheets Required for Power System Transient Stability Studies 10/8/2006 New 10/8/2011
Document
SABP-P-008 Inspection and Maintenance for Wooden Poles 1/21/2007 New 1/21/2012
SABP-P-009 Power Transformer Diagnostics 1/15/2007 New 1/15/2012
SABP-Q-001 Anchor Bolt Design and Installation 8/31/2002 New 9/1/2007
SABP-Q-002 Spread Footings Design 1/31/2005 8/31/2002 2/1/2009
SABP-Q-003 Vertical Vessel Foundation Design Guide 4/30/2005 7/31/2002 5/1/2009
SABP-Q-004 Heat Exchanger and Horizontal Vessel Foundation Design 8/31/2002 New 9/1/2007
SABP-Q-005 Storage Tank Ringwall Foundation Design 8/31/2002 New 9/1/2007
SABP-Q-006 Wind Load on Pressure Vessels 10/2/2006 New 10/2/1011
SABP-Q-008 Design of Concrete Masonry Walls/Buildings 2/28/2005 New 3/1/2009
SABP-Z-001 Plant Information Center Data Compression 12/19/2006 New 12/19/2011
SABP-Z-030 Wireless Process Remote Monitoring and Control Using SMS 11/21/2006 New 11/21/2009
Download:
