Hi, i need to build a diamond steel tank with 30m heigh and a capacity of 200 m3.
Is there a standard or software to achieve this? I only use cype for analisys and tekla for fabrication, none of them has the ability for analysing sheet metal. PVElite? Tank? Robot? Solidworks?
Would only need the diameter and shell thickness for column and tank, maybe beams to strengthen the column.
Thanks in advance.
