Hi All,
Would any1 be able to provide a spreadsheet or calculations (including Wind and Seismic) for Bolted Tanks usually used for Water Tanks. They could be designed to AWWA D103, but as long as they show the calculations quoting the relavant standard or if it is based on standard engineering calculations, that would be helpful. Would be nice if you could show all the detailed calculations, e.g. roof loading, self supported roof design , wall thickness due to loadings, bolt connections, anchor bolt connections, bolted attachments for external stairways, pipes etc. - basically all the calcs needed to design every part of the tank
If anyone could provide the detailed calculations would be much appreciated.
Thanx.
A.
Read more:[link Point to another website Only the registered members can access]
