Results 1 to 10 of 10
Thread: Motor Starting ETAP
    Motor Starting ETAP
    Dear All,
    I have problem with motor starting on ETAP. Anybody can help me with detail and comparison of DOL, D-Y starter, softstarter on ETAP please?
    iam3NG
    Re: Motor Starting ETAP
    I think ETAP models them as same as in motor starting theory. Actually, you can refer to the help file as you start to choose your starting device. DOL and Y-D starting are same as in theory. Softstarters, however, you have to be specific what type of starter it is. The only goal is, as a softstarter, is to limit current upon starting of motors, you will have to chose from the list.
    Quote Originally Posted by surgeArrester View Post
    Thank you Sir, but the result is confusing. When i use DOL, the voltage 88% but. and when i use current limit the result was same. Any detail for fill the etap data?
    I follow etap help as guidance.
    Iam3NG
    Iam3NG
    Quote Originally Posted by iam3NG View Post
    Iam3NG
    By the way, what kind of motor starting are we talking about here? Static or dynamic? So that we know where we could start on the lacking data.
    This is the good question, because i don't know to what the difference. I tried both of them at etap. Please kindly help me.
    If you really want to know the motor's acceleration time with torque-load modeling to the load of the motors, you are doing a motor dynamic study. If you only at least know the voltage dip without knowing the acceleration time(maybe) then static simulation is enough. You can check it in the motor's properties.
  11. Re: Motor Starting ETAP
    Thank you very much Sir,
    Thumbs up Re: Motor Starting ETAP
  1. Calculation of starting resistances for wound rotor motor
    By boswald in forum Electrical & Power Engineering
    Last Post: 02-12-2014, 06:17 AM
  2. Article: Motor starter and starting current
    By leon_aurel in forum Home Articles
    Last Post: 09-07-2012, 01:09 AM
  3. Motor starter and starting current
    By leon_aurel in forum Electrical & Power Engineering
    Last Post: 09-06-2012, 06:09 AM
  4. Starting Flogrid
    By 06pg22 in forum Reservoir
    Last Post: 11-25-2009, 05:53 PM
