Thread: Asme ptc
    Asme ptc
    Dear all,
    Can anyone upload the following ASME PTC standards?
    ASME PTC 12.4
    EN-Moisture Separator Reheaters
    ASME PTC 12.5
    EN-Single Phase Heat Exchangers
    ASME PTC 19.11
    EN-Steam and Water Sampling Conditioning and Analysis in the Power Cycle
    ASME PTC 19.12
    EN-PART 12: MEASUREMENT OF TIME INSTRUMENTS AND APPARATUS
    ASME PTC 19.13
    EN-PART 13: MEASUREMENT OF ROTARY SPEED INSTRUMENTS AND APPARATUS
    ASME PTC 19.2
    EN-Part 2: Pressure Measurement Instruments and Apparatus
    ASME PTC 19.22
    EN-Data Acquisition Systems
    ASME PTC 19.23
    EN-Part 23: Guidance Manual for Model Testing Instruments and Apparatus
    ASME PTC 19.3 TW
    EN-Thermo wells Performance Test Codes
    ASME PTC 19.7
    EN-Part 7: Measurement of Shaft Power Instruments and Apparatus
    ASME PTC 2
    EN-Definitions and Values Performance Test Codes
    ASME PTC 24
    EN-Ejectors
    ASME PTC 29
    EN-Speed-Governing Systems for Hydraulic Turbine-Generator Units
    ASME PTC 30
    EN-Air Cooled Heat Exchangers
    ASME PTC 36
    EN-Measurement of Industrial Sound
    ASME PTC 38
    EN-Determining the Concentration of Particulate Matter in a Gas Stream
    ASME PTC 39
    EN-Steam Traps
    ASME PTC 4.3
    EN-Air Heaters
    ASME PTC 6.1
    EN-INTERIM TEST CODE FOR AN ALTERNATIVE PROCEDURE FOR TESTING STEAM TURBINES
    ASME PTC 6A
    EN-Appendix A To PTC 6 the Test Code for Steam Turbines
    ASME PTC 70
    EN-Ramp Rates
    Thank you in advance.
  3. Re: Asme ptc
    up.
    waiting for someone to upload
  1. ASME PTB-3-2013 asme section viii div.2 ,example problem manual
    By lois in forum Mechanical Engineering
    Last Post: 02-25-2025, 01:20 PM
  2. Replies: 1
    Last Post: 07-29-2014, 10:26 PM
  3. Difference between ASME IX 2013 and ASME IX 2010 Add.2011
    By yakkidudu in forum Oil And Gas Production
    Last Post: 02-06-2014, 01:48 PM
  4. Need Guide For Asme Stamp Holders ASME A15100
    By PINTAIUS in forum Mechanical Engineering
    Last Post: 10-07-2012, 10:09 PM
  5. ASME PTB-3-2010 asme section viii div.2 ,example problem manual
    By sharmilasu in forum Mechanical Engineering
    Last Post: 04-22-2012, 06:57 AM
