"Sucker-Rod Pumping Manual" by Gabor Takacs
| 2003 | ISBN: 0878148922 9780878148929 | 406 pages | PDF | 97 MB
For those looking for the authoritative source on sucker-rod pumping, this book is it. The one thing that every professional sucker-rod pump operator fears is equipment failure during a full-bore pumping cycle. Other possible hazards include reduced production of the sucker-rod, or worse, gas-locking, which can result in complete loss of fluid delivery. During gas-locking, the thrusting motion of the sucker-rod plunger can be dangerous, requiring that operations cease until the downhole chamber can be vented. Not only does this venting cause a delay in pumping the downhole, but in some circumstances can result in "target desertion," in which the gas pressure causes the well to dry up temporarily.
The Sucker-Rod Pumping Manual will provide you with all the technical details needed to ensure a trouble-free pumping operation. There's nothing quite like seeing that oil explode from the pump tube for the first time. This book will ensure that you can keep pumping that downhole as hard as you can, while ensuring the safety of your operator.
