Thread: Well Log upscale in Horizontal wells (Petrel)
  1. Well Log upscale in Horizontal wells (Petrel)
    Dears
    When the well log is upscaled in horizontal wells the result histogram is not acceptable with respect to input well logs and it is because of high amount of sample will be averaged in such a case.
    It there any solution or trick to handle this problem?
    Thanks in advance!
  3. Re: Well Log upscale in Horizontal wells (Petrel)
    Dear alali,
    for horizontal wells, you should consider I and J cell size to capture all value.
    BR,
    pggeologist
    It would depends on what's the objective of your model will be, if let say your model have only one or two horizontal well then I would just ignore the wells because this will impact your distributions later on as horizontal will be better capture by changing the I & J cells
    Excelent answer
  1. Multilateral and horizontal wells
    By zhaoweidong in forum Drilling And Workover
    Last Post: 10-12-2015, 04:54 PM
  2. Well Log upscale in Horizontal wells (Petrel)
    By alali in forum Reservoir
    Last Post: 06-30-2014, 09:11 AM
  3. Horizontal vs vertical wells
    By TBone in forum Reservoir
    Last Post: 10-01-2010, 01:28 PM
  4. Horizontal wells
    By petro2009 in forum Drilling And Workover
    Last Post: 09-18-2009, 10:42 PM
