Industrial dryer usually uses rotary cylinder. There is a material lifting board on the wall of cylinder. When the industrial dryer rotates, cylinder is in a certain angle. After entering the cylinder from high end, material will slowly flow to the low end under the action of gravity and cylinder rotation. In flowing process, there is continuous hot air through the space of cylinder, thus taking away the moisture contained in the materials. And do you know how many main kinds of industrial dryer in mining market at present?
At present industrial dryer is roughly divided into: industrial dryer, rotary dryers, rotary drum dryer, industrial dryers. And the application scope of industrial dryer is as follows: industrial dryer, rotary drum dryer is widely used in food, feed, chemical, pharmaceutical, mining and other industries.Equipment working process is as follows: the wet material after joining dryer after dehydration, inside the cylinder under uniform of copy board flipping, material in the dryer evenly dispersed in contact with the hot air fully, to speed up the drying heat transfer, mass transfer.In the process of drying, copy board and heat properties of materials with gradient, under the action to the drying machine another star discharge valve to discharge the finished product.This machine is suitable for water cut is less than 85% of all kinds of bad slag material drying, such as brewer's grains, bean dregs, shotcrete corn husk, slime and pomace, etc., to open up feed resources, lower investment cost, reduce the pollution of the environment has a good effect.
Our main export is vibrating drum dryer drying equipment, vacuum drying equipment, small and medium-sized food, food and agriculture, forestry and native products drying equipment, annual export more than a few hundred units, is the main area of the southeast Asian countries and other developing countries, and have opened the door to the European and American market.
What's more, as a
[link Point to another website Only the registered members can access] info@sinoftm.com.
fluorite ore dryer:
