Ball press machine is designed to press coal powder,sponge iron powder,sludge,kaolin clay,activated carbon , mill stone ,fgd gypsum , slag, fluorite powder,iron ore powder, calcined lime ,copper powder,manganese alloy,iron oxide skin,aluminum powder, manganic mineral, chromium ores powder and etc into all various shape briquettes with high density,the common ones are pillow/diamond(square)/oval,rectangle. But have you ever known the sponge iron ball press machine up to now?
At present, Chinese economy is undergoing rapid development and at the same time, the pace of infrastructure construction is also accelerating. All these require lots of raw material inputs, in which steel is essential as a major material in construction market in economic development. The current development of Chinese machinery industry is accelerating, which will procure scrap metal shavings continue to increase. As these scrap metal shavings are relatively small, it is difficult to recycle because of the inconvenience in transportation and other areas.
Sponge iron ball press machine is mainly used for pressing hard to molding of powder material, its characteristic is the molding pressure big, main engine RPM adjustable, equipped with spiral feed unit. Mainly used in the pulverized coal forming; Dry powder molding; The desulfurization gypsum mounding; Coke powder molding; Iron ore and all kinds of metal powder molding, etc. Used for non-ferrous and ferrous mineral powder briquette /ball making system before the smelting furnace, like iron ore concentrates, chromate ore concentrates, steel slag, aluminum ash, Si-Mn mineral powder etc. Also used in coal ash, coal mud, coke powder, coking coal, refractory and metallurgical powder Cold pellet making industry.
Fote machienry is a pprocessional ball pressing machine manufacturer, we can offer you with desulfurization gypsum pressure ball machine; cinder ball press machine; steel slag ball press machine and so on. If you have any other question or have an interest on our product ,you can write to us: info@sinoftm.com.
small ball press machine:[link Point to another website Only the registered members can access]
desulfurization gypsum pressure ball machine:[link Point to another website Only the registered members can access]
steel slag ball press machine: [link Point to another website Only the registered members can access]
