hi, i'm new to this board.
i installed aspen plus and when i try to choose liq-liq/liq-vap for red frac, it presented nothing.
here is the picture
anyone knows what'd i do?
sorry for my poor english, i just started learing it
here is the picture
I also have this problem. There are many required input that I try to choose but it presented nothing.
Please help me. Thanks.
i encountered the same problem and the solution was to use the (tab) button to select your input
choose your input using tab then hit enter to confirm that input.
hope it helps
Thank you, but it's unsuccessful. I tried to do with your solution but I couldn't choose. Thank you again!HTML Code:i encountered the same problem and the solution was to use the (tab) button to select your input choose your input using tab then hit enter to confirm that input. hope it helps
i have problem in istallation of aspen one v7.1 under windows 7 after i make every thing when try to run any module messages appear liecense not able to handeled and want database
i wish useful help in the program i want to run pls all experience members
windows 7 ultimate 32
i buy lab top for running the program pls help me
i will be greatgull for member who will solve this problem
if one can know the solution for the problem give me points of solution to do and running the program
