Wild Well Control (2006)
Table of Contents :
1) Acronyms & Abbreviations
2) Common Formulas & Equations
- Capacities & Volumes for Downhole
- Capacities & Volumes of Tanks
- Pump Output & Rate Formulas
- Pump Pressure Relationships
- Equivalent Circulating Density
- Trip Calculations
- Pressure & Gradient Formulas
3) Kick Related Formulas & Equations
- Kill Sheet Calculations
- Kick Related Formulas
- Volumetric Method Calculations
- Lubricate & Bleed Calculations
- Bullheading Calculations
- Stripping Calculations
- Subsea Formulas
- Accumulator Sizing
- Mud & Cement Formulas
- Hydraulics Formulas
4) Estimates & Rules of Thumb
- Tripping
- Stuck Pipe
- Free Point and Stretch Estimates
- Temperature Drop Across Choke or Orifice
- Gas Well Flow Rates
- Area of a Circle
- Force and Pressure
- Weight of Spiral Drill Collars
- Buoyancy Factor
- Pipe Elongation Due to Temperature
- Surface and Bottom Hole Pressures in Full Gas Column
- 4) Piping & Other Data Tables
- Drillpipe – Range II
- Drillpipe Capacity & Displacement
- Heavy-Weight
- Drill Collars
- Drill Collar Capacity & Displacement
- KILL SHEET
- API Tubing
- Premium Connection Tubing
- Casing Strength
- Casing Capacity
- Hole Capacity
- Triplex Pumps at 100% Efficiency
- Mud Weight Adjustments
- Mud Weights
- Specifications for BOP Flanges, etc.
- Gate Valve Data
- API Ring Joint Flanges
- BOP Fluid Operating Volumes
- Coiled Tubing Data
- Coiled Tubing Dimensions
- Electric Line
- Wireline Data
- Conversion Factors
The Link :
