Results 1 to 7 of 7
Thread: Petrel for new user
    Aug 2013
    Ho Chi Minh city, Viet Nam
    Petrel for new user
    Hi guys.
    i'm studing Petrel RE and I have some problems
    - who can help me some data files of the book named Petrel RE 2007 or 2010
    - I can't run 'define simulation case' process, because it needs eclpse 100 or 300 or FrontSim. Must I install those programs together with petrel? I'm using Windows 8.1 64bit
    my mail: nguyendangtruong1111@gmail.com
    Re: Petrel for new user
    You should be able to run the process 'define simulation case' even though you don't have Eclipse or FrontSim installed.
    Aug 2013
    how can i do when it report 'error license'. i'm using petrel cr*cked
    To run define simulation case you must have Eclipse installed in your PC. Basically define simulation case is to prepare data file for eclipse which will be run by Eclipse if Eclipse software is installed in your PC. After installing Eclipse software in your PC you have to modify your environmental variable to run Petrel and Eclipse simultaneously. To run for fronSim it is not necessary to load the fortntSim software to be loaded if have FrontSim locked available in your Petrel.
    no need to have eclipse for define simulation case ... however you can not use Check and Run button ... you should just export your simulation case into a folder .... if you click on "Export" only than your data deck for eclipse will be prepared you can run them separately to Eclipse if you want later
  1. Replies: 35
    Last Post: 03-11-2019, 08:08 PM
