Thread: Absorption of Aromatics Compounds (BTEX) in TEG Dehydration Process
    Hi, dear freands!
    We are running standart TEG dehydration unit, which design for gas flow 15 MMSCFD of day at pressure 30 bar and gas temperature +25 deg. C. We are using TEG to get water dew point -15 deg. C. After few month of running we get problems with water dew point, which is now is +2 deg. C and we found that 50 % of water from glycol sump tank is aromatic hydrocarbons like benzene, toluene, ethylbenzene, and xylene. Total flow from glycol sump tank is 300 lit/day. 50% is water and 50% is of liquid is hydrocarbons (aromatics) with SG 0.816-0.840. The lean TEG now is 83% by mass so regeneration system does not work properly. This confirms with high water dew point +2 deg. C.
    Please if you have any ideas what we can do with this issue
    Re: Absorption of Aromatics Compounds (BTEX) in TEG Dehydration Process
    pl provide some more details like pfd if available
  1. Organophosporous compounds
    By pkarambele in forum General Engineering
    Last Post: 07-28-2013, 07:40 PM
  2. Absorption and Stripping
    By nay_den in forum Petrochemical
    Last Post: 05-23-2013, 09:03 AM
  3. Article: Chemical formulas of common compounds
    By malhussiny32 in forum Home Articles
    Last Post: 05-02-2011, 10:28 PM
  4. Chemical formulas of common compounds
    By malhussiny32 in forum Laboratory Measurements
    Last Post: 04-28-2011, 06:02 PM
  5. Elements, Compounds & Mixtures
    By Foad in forum Petroleum Refining
    Last Post: 01-02-2008, 12:21 PM
