Hello,
Do you have a material or a simulation with crude atmospheric distillation in hysys or aspen hysys? Thank you!
Hello,
Hi
check simulation files in SAMPLES Folder from HYSYS installed Directory
In Aspen HYSYS you can run 3 Types of petroleum Distillation
1-Rigorous column -most important -any HYSYS version
2-Petroleum from Refsys pallete operations-or as template FCC,HYDRO-----ER Reactors with column-starting with HYSYS/REFSYS 2004
3-Aspen Plus Petroleum Column-you must choose Aspen Properties as thermo pack and add EO subflowsheet from add operation submenu and try to translate example from ASPEN PLUS-starting with Aspen/Refsys/hysys 2006
As documentation try with help and Manual Documentation
can some one tell me how to calculate number of stages in hysys.there are first 30 alkanes in my feed stream to column.i am doing project on fischer Tropsch process
