Thread: AFT Impulse 5
  1. AFT Impulse 5
    Hi all,
    There is a new version of AFT impulse, a software for transient flow analysis. If there is a fix or a --------?
    The AFT Impulse 5 New Features are (from official site web) :
    - General interface
    Updated interface and icons
    Robust support for dual monitors
    Native support for both 32-bit and 64-bit operating systems
    Tabbed Primary window navigation with individual window pullout feature
    New Startup panel allows user to choose engineering unit system (U.S./metric) and specify default fluid
    Improvement of main menu navigation including redesign of the Checklist
    Primary window toolbars now integrated into each Primary window
    Non-settling slurry features accepts raw rheological data and generation of non-Newtonian constants as well as new raw data Scale-up model
    New User Options window collects many of the previous user customization windows into one place – including Parameter and Unit Preferences, General Preferences and Workspace Preferences
    Improved printing features includes use of company logo, user comments and titles, as well as graphical borders on all printouts
    Help menu links to video tutorials on our website
    When merging models users can automatically create a group of merged pipes and junctions
    User customizable themes
    Output reports available in Spanish language
    Curve fit configuration window parameters and unit selection have been improved
    Files are automatically locked when opened to prevent multiple users from accidently opening the same file
    Additional parameters are available to control the solution calculations
    - New Quick Access Panel
    Access to Scenario Manager directly in interface
    Access to Graph Sets directly in interface
    Access to Workspace model overview map
    Alternate display of Input and Output data for pipes and junctions
    Users can pin the Panel or use it in flyout mode
    - Scenario Manager
    Access through Quick Access Panel from any Primary Window tab
    Insert Scenario feature allows new scenarios to be inserted above any scenario including the Base Scenario thus creating a new Base
    Delete All Children feature means children do not need to be deleted one at a time
    - Workspace
    Transparent icons gives more modern look to model
    Mapping feature flyout allows birds-eye view of model and navigation
    Dockable and movable Toolbox
    Toolbox icon changes can be made using a right mouse click on the Toolbox
    Select cursor or Pan cursor selectable on the Toolbar
    Improved navigation speed for large models with thousands of pipes and junctions
    Improved Inspection window more readable and has integrated Output data with Input
    When trying to move locked pipes and junctions a lock symbol appears next to locked items that cannot be moved
    Annotations capability great improved also allowing user’s images to be inserted into the annotation
    Improved pipe and junction graphical interference detection
    Last selection on the Workspace can be reselected using F12
    -Model Data
    General, Pipe and Junction data display sizes can be changed by user and more easily hidden
    New zoom feature added
    Curve fit raw data is now an available display parameter
    Pipe intermediate elevations added as an available display parameter
    - Output
    General, Pipe and Junction output report display sizes can be changed by user and more easily hidden
    New parameters available
    Display multiple instances of the same parameter with different units
    Output Control parameter selection improved and made uniform
    Parameter units are selected next to the parameter in the grid
    -Graph Results
    Improved Graph Set creation and navigation integrated into Graph Results window Quick Access Panel
    Junction symbols can be shown on Profile and HGL/EGL/Elevation graphs allowing easy identification of the location within the model
    AVI and flash video files can be created from the animated graphs
    Annotations can be placed directly on graphs
    Design Alerts and Steady-state values can be cross-plotted in both animation and Maximum/Minimum plots
    - Pipes
    Fittings and losses can now have user “Favorites” which allows for much faster navigation to frequently used fittings
    Improved pipe sectioning window
    New Pipe Material Databases based directly on international pipe standards (databases coming soon)
    Pipe data can be changed using the Excel file import feature
    Ability to specify a reference pressure in a closed pipe during steady-state which will be used during the transient calculations
    - Junctions
    New Weir junction allows direct modeling of sharp-crested weir of varying geometry
    Enhanced Relief Valve modeling, including Danflo and Grove Flexflo
    Pump specific speed and estimated inertia calculator integrated within the pump propertied window
    Pump de-rating by user specified factors adds to previous calculated de-rating methods
    Reference density for all pump head curves and junction resistance curves allows correction for pressure drop data, mass flow data and (for pumps) power data
    New Kv loss model for valves
    New pump viscosity correction method utilizing ANSI/HI 9.6.7-2004 method
    Check valves can be specified to be closed (using Special Conditions) during steady-state but then open and operate normally during the transient
    - Solver
    Automatic processor threading decreases time required to solve transient cases
    Discrete Gas Cavity model to calculate cavitation
    Improved support of pressure drop in fittings by use of the Adjusted Turbulent K factor method
    Handle varying ambient pressure with elevation
    Force imbalance calculations can now extend across more than two pipes
    - Modules
    SSL – New settling slurry module (similar to AFT Fathom) allows solid particles to be added to the working fluid. The system can then model the slurry transient based on a new density, bulk modulus and wave speed based on these solid particles.
  3. Re: AFT Impulse 5
    Please share AFT Impulse tutorial.
  5. Re: AFT Impulse 5
    Please share AFT impulse 5 software along with license
    thanks in advaance
    Re: AFT Impulse 5
    hi guys can any one share AFT Impulse 5 with LIc....
  1. Impulse Tubing
    By borrise in forum Instrumentation & Control
    Last Post: 01-24-2014, 05:02 AM
