Thread: Hydrate Formation Temperature
  1. Hydrate Formation Temperature
    Dear all,
    I want to calculator Hydrate Formation Temperature with the natural gas is not saturate water (use Hysys software)? I want to check hydrate formation in the gas go out of the Adsortion Unit. Can anyone help me? Thank you
  3. Re: Hydrate Formation Temperature
    you can so it however hysys formation temp is not accurate. I work with gas hydrate every day and noticed the best sim for hydrate formations in Multiphase or pipesim depending on gas composition
    Procedure for Hysys
    Locate the stream exiting your adsorption unit
    Double click to enter stream properties
    Go to Attachments
    Create
    Hydrate Formation Utility then add utility
    New window will open showing
    Hydrate formation Flag (hydrate will form or not)
    Type of Hydrate
    Click on Performance Tab to acquire the formation temp for hydrate
  5. Re: Hydrate Formation Temperature
    Procedure for Hysys
    Go to Attachments
    Create
    Type of Hydrate
  1. Replies: 1
    Last Post: 05-13-2013, 06:23 PM
  2. Hydrate formation article
    By mouss in forum Pipeline And Fluid Flow
    Last Post: 03-16-2013, 09:57 PM
