Results 1 to 10 of 10
Thread: Etap12.5
  1. Etap12.5
    ETAP 12.5 adds a broad and robust set of new enhancements to the ETAP suite, as well as powerful new
    analysis modules and time-saving capabilities. These include:
    • Dynamic Parameter Estimation & Tuning - DPET
    • GOST Short Circuit - R 52735 Standard
    • Distributed electrical SCADA technology
    • Thin-client consoles
    • Web real-time consoles
    • Native SCADA Communication Protocols
    • IEC 61850 substation automation
    • Phasor measurement unit archive and visualization
    • Waveform capture and visualization
    This New Features Guide describes important new capabilities in ETAP 12.5. These new features and
    functions demonstrate our shared commitment to customers and business partners to provide the
    most comprehensive solutions for the design and operation of critical power systems now, as well
    as the energy technologies for tomorrow.
    For nearly three decades, ETAP has been the leading modeling platform used to design, analyze,
    and optimize electrical power systems in the most demanding industry applications. Similarly,
    ETAP Real-Time™ – which has been providing online diagnostics, predictive simulation, optimization,
    and management of power systems for more than 20 years – has been deployed in a multitude of
    customer installations to ensure their reliable and energy-efficient operation.
    GOST Short Circuit
    R 52735 Standard, Russian Federation and CIS Countries
    ETAP 12.5 supports a new method of short circuit calculation in compliance with GOST R 52735 Standards.
    Built-in intelligence allows the short circuit program to automatically apply all GOST factors and ratios
    required for high voltage short circuit calculations. By automating the process with multiple calculation and
    results analysis tools, ETAP 12.5 removes the guesswork from short circuit studies, and saves users hundreds
    of hours of tedious hand calculations.
    New capabilities include:
    • Calculate periodic and aperiodic components, as well as surge current
    • Calculation of short circuit current at any specified time
    • Radial and multi-loop circuit calculations
    • Consider pre-fault loading condition
    • Short circuit output report in Russian language
    Multi-Knowledge of a rotating machine and its associated control system dynamic parameters is essential to
    power system transient stability simulation studies. These parameters include machine impedances and
    time constants, inertial and damping coefficients, prime mover and governor parameters, excitation system
    and AVR parameters, Power System Stabilizer (PSS) parameters, load characteristics, etc.
    DPET is especially useful for Power Plant Model Validation, as mandated by North American Reliability
    Council (NERC) MOD-026 and MOD-027 Standards. MOD-026 will require power plant owners to verify
    that dynamic models of excitation controls are accurate and up-to-date; MOD-027 places the same
    requirements on dynamic models of governors and turbine controls.
    DPET features and benefits include:
    • Generate comparisons of multiple estimation results
    • Utilize ETAP User-Defined Dynamic Model to build custom models
    • Combinations of Models: Generators, Governors, Exciters, PSS, etc.
    • Utilize field data from disturbance recorders and PMUs
    • Tune dynamic models with multiple inputs and outputs
    • Estimate model parameters using field measurements
    • Compliance with NERC MOD Standards
    • Automatically exclude questionable data and noise
    • Multi-objective stochastic optimization method
    Accuracy in hundreds of these parameters directly affect the
    credibility of the simulation results.
    In order to Verify and Validate (V&V) simulation studies, it is common to compare simulation results against
    field test measurements such as generator load acceptance and rejection test. However, expertise is required
    to understand the effect of each parameter, as the simulation model is manually tuned to provide similar
    response as the one observed in the field tests or recordings. The task of adjusting each variable via the
    trial-and-error approach is a tedious and time-consuming one.
    DPET adds an intelligent automated layer of time saving capabilities. Combined with ETAP User-Defined
    Dynamic Models (UDM), DPET automatically adjusts appropriate parameters so simulation responses
    match actual field measurements accurately in a matter of minutes, rather than weeks.
    So, what's the question?
    Sent from my GT-I9082 using Tapatalk
  5. Re: Etap12.5
    You call This thread ?
  6. Re: Etap12.5
    Don´t like this one! This thread must be deleted.
    Oct 2009
    Dehli, Delhi, India, India
    Blog Entries
    1
    Re: Etap12.5
    Dear Brother's, Trust you are well & Enjoying life. Any news regarding ETAP 12.5. Keep all inform if any good news. God Bless you all.
    There is a post that the solution for etap v11 works on etap 12.5 however it asks for a key.
  10. Re: Etap12.5
    Quote Originally Posted by surgeArrester View Post
    Do you have the installation files for etap 12.5 ?
    Re: Etap12.5
    Whether etap 12.5 has --------
  12. Re: Etap12.5
    yes, it works.
    Re: Etap12.5
    anyone who have the Etap 12 _______. please share
