Hi guys, do you know what is the reference normative for pressure vessel positioning tollerances?
Verticality, anchor bolts position,....
Thanks a lot
Thanks a lot
Have no one of you experience in assembly?
I need to know the references for vertical vessel erection in site.
Sorry double post.
Hi, the values you posted are used in common practice. I would know if there are international standard for this work area, ad well as the 31.3 forma piping erection.
Inviato dal mio Nexus 5 utilizzando Tapatalk
.Hi, You will find some requirements of dimensional tolerances for manufacture of pressure vessels at ASME Code
There are also standard practices as PIP whit additional requirements
Some times customer or the EPC has his owns.
