Thread: Solving tribology problems in rotating machines
    H Prashad, Bharat Heavy Electricals Limited (BHEL), India
    ISBN 1 84569 110 5
    ISBN-13: 978 1 84569 110 3
    January 2006
    264 pages 234 x 156mm hardback
    £135.00 / US$255.00 / €170.00
    - discusses improved machine performance
    - examines factors affecting bearing reliability
    - an essential reference for engineers
    Solving Tribology Problems in Rotating Machines will be an essential reference for people involved in the design and operation of rotating machines in sectors such as power generation, the steel industry and electrical and automotive engineering
    Bearings are widely used in rotating machines. Understanding the factors affecting their reliability and service life is essential in ensuring good machine design and performance. Solving tribology problems in rotating machines reviews these factors and their implications for improved machine performance.
    The first two chapters review ways of assessing the performance and reliability of rolling-element bearings. The author then goes on to discuss key performance problems and the factors affecting bearing reliability. There are chapters on cage and roller slip, and particular types of failure in equipment such as alternators, condensers and pumps. The author also reviews the effects of such factors as localised electrical currents, seating, clearance, grades of lubricant, axial forces, vibration on performance and service life. The book concludes by reviewing ways of improving bearing design.
    .Contents
    Reliability Analysis of Rolling-Element Bearings
    Detection of Bearing Malfunction and Determination of Defect Frequencies
    Resonant Frequencies
    Experimental Procedure
    Instrumentation Details and Techniques
    Determination of Defect Frequencies and Energy Levels
    Functional Performance of Rolling-Element Bearings for Acceptance in Routine Applications
    Bearing Test Philosophy
    Bearing Test Machine
    Data Deduction
    Results and Discussion
    Overall Vibration Levels of Bearings
    Predicted Life of Bearings
    Comparison of Performance of Bearings
    Cage and Roller Slip of Rolling-Element Bearings
    Characteristic Defect Frequencies
    Spectral Analysis Technique
    Comparison of Bearings
    Diagnosis and Cause Analysis of Rolling-Element Bearings Failure in Electric Power Equipment
    Bearing Arrangement and Nature of Bearing Failure
    Investigations, Observation of Failures and Data Collection
    Localized Electrical Current in Rolling-Element Bearings
    Bearing Arrangement and the Nature of Bearing Failure
    Investigations, Observations and Data Collection
    Theoretical Model and Approach to Determine the Flow of Localized Current in a Bearing
    Field Strength on Track Surfaces of Races and Rolling-Elements
    Magnetic Flux Density
    Determination of Time Span for the Appearance of Flutes on Track Surfaces
    Response and Performance of a Rolling-Element Bearing Under the Influence of an Electric Current
    Behaviour of Grease in Non-Insulated Bearings
    Effect of Current on Formation of Corrugated Patterns on the Roller Track of Races of Roller Bearings
    Effect of Current Leakage on Electro-Adhesion Forces in Rolling Friction and Magnetic Flux Density Distribution on Bearing Surfaces
    Effect of Operating Parameters on the Threshold Voltages and Impedance Response of Non-Insulated Rolling-Element Bearings
    Impedance, Capacitance and Charge Accumulation on Roller Bearings
    Contact Temperature, Contact Stresses and Slip Bands Initiation on Roller Track of Races
    Effects of Instantaneous Charge Leakage on Roller Tracks of Roller Bearings Lubricated with High-Resistivity Lubricants
    Capacitive Effects of Roller Bearings on Repeated Starts and Stops of a Machine
    Mechanism of Bearing Failures
    Effect of Oil Grades and Clearance Ratios on the Reliability of Cylindrical Hydrodynamic Bearings
    Theoretical
    Evaluation of Viscosity Coefficients
    Determination of Viscosity Integral
    Assessment of Bearing Performance
    Effect of Oil Grades on Temperature Rise and Safe Load-Carrying Capacity of Bearings
    Bearing Turbulence and Transition Speed
    Spherical Seating of Hydrodynamic Journal Bearings
    Theoretical Basis of the Simplified Design Methodology
    Evaluation of Minimum Values of Constant of Moment of Friction and Optimum Values of the Design Parameters of Spherical Seating
    Functional Nomographs for Evaluation of Optimum Values for Spherical Seating Design Parameters
    Guidelines for Choosing the Optimum Values for Spherical Seating Design Parameters
    Life Estimation of Turbine Oils: A Methodology and Criterion for Accpetance or Rejection
    Experimental Investigations
    Data Deduction
    Axial Force on Motor Bearings: A Tool For Performance Evaluation
    Axial Force Measurement Technique
    Experimental Determination of Axial Force
    An Analysis of the Progressive Increase in Vibration of a Large Synchronous Electric Motor
    Possible Sources of Vibration
    Diagnosis of Causes of Vibration
    System Design, Bearing Assembly and Characteristic Features of the Synchronous Motor Under Investigation
    Investigations and Analysis
    A Study of the Causes of Failure of Rolling-Element Bearings in Alternators
    Design Features of the Alternators
    The Nature of Bearing Failure
    Data Collection and Investigations
    Causes of Shaft Voltage and Flow of Current Through Bearings
    The Diagnosis of the Cause of a Bearing Problem in a Synchronous Condenser
    Technical Details of the Synchronous Condenser
    Measurement Obtained
    Theoretical
    Comparison of Theoretical and Experimental Data
    The Cause of Noise at the Top Bearings of Vertical Pump-Motor Sets
    Sump Layout and Construction
    System Layout
    System Behaviour
    Factors Causing the Unusual System Behaviour
    Vibration Spectra and Analysis
    Design of the Bearing Used and its Significance
    Explanation of the Cause of Noise at the Motor Top Bearing
    Modifications to the Design and Bearings of Horizontal Axis Windmills Used for Pumping Water, to Achieve Trouble-free, Reliable Operation
    Design Features
    Operational Philosophy
    Transmission System
    Bearings and Performance of the Reciprocating Pump
    Magnetic Suspension Bearings for AC Energy Meters
    Design Considerations
    Mechanical Requirements
    Typical Construction
    Frictional Torque Studies
    A New Generation of Rolling-Element Bearing with an Outline of its Performance Advantages
    Basic Concept and Principle of Operation of DDHPB
    Theoretical Analysis
    Theory Behind Performance Evaluation of Bearings
    Design and Test Conditions of DDHPB
    Bearing Test Set-up and Experimental Details for Testing DDHPB vis-a-vis Conventional Bearings
    Here is the link
    thanks a lot
    Dear Sir,
    Can you mail the book to sskctx@gmail.com or upload in any other link.
  1. rotordynamic of rotating machines
    By giova70 in forum Mechanical Engineering
    Last Post: 07-26-2014, 10:55 PM
  2. IEC 60034 Rotating electrical machines
    By Krivitski in forum Mechanical Engineering
    Last Post: 09-19-2011, 05:45 AM
  3. Tribology of Metal Cutting
    By Abdel fatah in forum Materials Science &Corrosion
    Last Post: 01-23-2009, 03:18 PM
  4. Tribology of Abrasive Machining Processes
    Last Post: 01-22-2009, 10:21 PM
