Thread: Internal floating Roof question
    good afternoon
    We are designing a tank storing petroleum fuels (gasoline and diesel) as well as ethanol and biodiesel for blending.
    In reviewing several recommendations I find that ethanol and gasoline tanks should be primarily floating roof. I know that an external floating roof tank does not require any pressure relief systems but my doubt arises with internal floating roof (IFR) tanks.
    I wonder if a gasoline tank designed as IFR requires a tank blanketing system and if this system is applicable API standard 2000 applies.
    Thanks.
    Ing Esteban Lopez
  3. Re: Internal floating Roof question
    Good day,
    Design of floating roof using the smaller of the specific gravity of API 650 sec H 4.2.6 (0.7), or the minimum specific gravity of the liquid stored in the tank.for venting of tanks follow the API 2000.
    srini
    naiduys@gmail.com
    Quote Originally Posted by esloar View Post
    good afternoon
    Thanks.
    Ing Esteban Lopez
    Oct 2008
    Athens - Greece
    Dear friend,
    I believe that internal floating roof, inside a fixed roof storage tank can be justified only in case of an aviation jet-fuel application, where rain-water must be kept out of reaching the hydrocarbon product, and not for storage of gasoline or diesel, in which case you can consider external floating roof for gasoline and fixed roof storage tank for diesel.
    Panos
  6. Re: Internal floating Roof question
    good afternoon
    we design a tank of ethanol with dome roof and a floating roof to prevent water contamination
    appreciate any feedback
  1. External floating roof
    By DesEng in forum Mechanical Engineering
    Last Post: 01-10-2014, 09:37 AM
  2. Internal Floating roof Tank Erection Sequence
    By anamma99 in forum Oil And Gas Production
    Last Post: 11-30-2013, 11:12 AM
  3. Professional Internal Floating Roof Manufacturer
    By zxshws in forum Mechanical Engineering
    Last Post: 08-26-2010, 09:37 AM
  4. Internal Floating Roof /Cover
    By addictive in forum Petroleum Refining
    Last Post: 09-04-2009, 05:43 PM
  5. Literature or code of Internal Floating Roof/Cover
    By addictive in forum Mechanical Engineering
