Thread: Maximum Flow Capacity Calculations
  1. Maximum Flow Capacity Calculations
    Dear Friends
    I want to calculate maximum flow capacity in existing 24" pipe. This pipe is header for some gas wells and outgoing gas transfers with 30" pipeline. Which standards should I use? Which criteria and formula?
    Thanks in advance.
    Re: Maximum Flow Capacity Calculations
    HI As far as I know there is no strict figure for gas velocity . parameters such as pipe material ,allowable pressure drop and..... are important . but have it in mind that
    this velocity must not reach to sound velocity in this media.all figures are recommended vel. i should note that higher velocity means higher pressure drop.
    I wonder why header is larger than transferepipe
  1. Replies: 215
    Last Post: 08-10-2018, 06:00 AM
  2. Piping Calculations Manual (Mcgraw-Hill Calculations) by SShashi
    By rioca57 in forum Pipeline And Fluid Flow
    Last Post: 11-19-2013, 09:01 PM
  3. Three phase flow calculations
    By isaka in forum Oil And Gas Production
    Last Post: 05-09-2010, 08:42 AM
  4. Need Help With Pressure Gradient Calculations in Multiphase Flow System
    By tangential87 in forum Oil And Gas Production
    Last Post: 10-03-2009, 04:05 PM
