Thread: Flange rigidity check
  1. Flange rigidity check
    IS it necessary to calculate flange rigidity for hydrostatic pressure established as per UG-99(b) or UG-99(c)?
    Re: Flange rigidity check
    Flange Rigidity in Hydrocase is not required- See below ASME Interpretation
    Interpretation: VIII-1-10-41
    Subject: Appendix 2, 2-14; UG-99(b); UG-99(c); and Interpretation VIII-1-07-52 (2010 Edition)
    Date Issued: August 30, 2011
    File No.: 11-1236
    Question: In satisfying the provisions of Appendix 2, 2-14, is it required to calculate the flange rigidity for
    hydrostatic test condition with test pressure established as per UG-99(b) or UG-99(c)?
    Reply: No.
  1. Din flange std
    By sakesit in forum Mechanical Engineering
    Last Post: 07-05-2018, 11:25 PM
  2. API flange vs ASME flange
    By aap in forum Mechanical Engineering
    Last Post: 07-09-2013, 12:34 AM
  3. DIN flange
    By bamuti in forum Pipeline And Fluid Flow
    Last Post: 07-02-2013, 02:29 PM
  4. API 6A - blind flange
    By rainie1284 in forum Mechanical Engineering
    Last Post: 04-15-2010, 11:22 PM
  5. Puddle Flange
    By VanniDiCarlo in forum Mechanical Engineering
    Last Post: 03-31-2010, 12:48 PM
