Thread: Startup Operation of Centrifugal Pumps
  1. Startup Operation of Centrifugal Pumps
    Good day to all,
    I would like know what are the effective steps to start a centrifugal pump? Should the discharge valve be throttled before starting the pump? If Yes/No . Please explain both cases?
    Jan 2011
    Bangkok, Thailand, Thailand
    Re: Startup Operation of Centrifugal Pumps
    Dear,
    A small pump ie 5 kw need not to throttle but big pump need.
    Consider at pump curve, if you do not throttled valve the pump will be run a few minutes then motor overload.
    This is because the pump experience an Overflow, running too high flow rate at low head. In all automatic mode, this is a must do.
    For small pump, you start the pump, the pump can fill pipe to make enough back pressure in time.
    Kittipong
    Jan 2011
    Dear,
    Kittipong
    You can status a centrifugas pump without control valve if You put a vfd on the motor. In This case You control the speed pump
  1. An introduction to Centrifugal Pumps
    Last Post: 01-26-2012, 01:35 PM
  2. Controlling centrifugal pumps
    Last Post: 08-08-2011, 05:47 AM
  3. Replies: 0
    Last Post: 07-26-2011, 11:36 AM
  4. Centrifugal Pumps (Part- I)
    By Mohamed in forum Mechanical Engineering
    Last Post: 09-17-2009, 09:01 AM
