Hammer crusher is a standard crushing machine. Because of the advantages of stable performance and the small size, it is loved by major of the users. It also breaks the monopoly situation of the foreign machine in domestic crushing industry. After decades of transformation, the function of hammer crusher is better than before. Hammer crusher is composed of the main body, coping, rotor, screening board and the adjustment device.
Single-stage hammer crusher is composed with rotor, bearing, discharge grate, bearing plant , main body and the drive section. The hammer head will strongly hit the ore in the crushing chamber. The ore will be crushed because of the collision between the back liner and ore. Rude ore enters into the feeding port of the crusher through the heavy feeding equipment (apron feeder with adjustable speed). The rude ore will be primarily crushed by the hammer head. The initial crushing material will be further crushed during its movement process. After the crushing process, the crushed material will be discharged into the discharge area. The final crushing process is finished in the lower crushing chamber.
To the mining company, the abrasion of the crushing equipment is the common phenomenon. Because of the working environment and the crushing material, the crushing machine needs the daily check, which causes the increasing of the cost. To the quick-wear parts of the hammer crusher, the composed parts are essential. We should conscientiously choose the lining board, hammer head, impact plant and the jaw plant. The bad quality of those parts will have great effect on the crushing efficiency of the hammer crusher. In order to solve the situation that the low temperature has bad effect on the hammer crusher, the experts from Fote Machinery research the existing crusher and improve its performance to use it under the low temperature condition.
screw classifiers:[link Point to another website Only the registered members can access]
