Can someone with real experience on Nozzle/Pro comment on the software? Is it worth the trouble or should one stick with WRC?
It is very much useful. It is beyond WRC and zick analysis...very useful handy and easy to use tools. But for proper application and proper troubleshooting you must have knowledge of finite element analysis basics.
Hope it is useful.
Thanks.
Thank you for the quick answer.
More concrete questions:
a) Is it quick? Does it take seconds or minutes to check one nozzle?
b) Is it possible to feed it with a text file describing the geometry? Can it run in batch mode? A column with 20 or 30 nozzles is nothing unusual.
c) Does it produce a full report that a Third Party would accept? If so, does the report need tweaking? Do I need to prepare the report myself?
d) Does it have a library of available nozzles? Apart from pipes/WN/LWN, are any manufacturer's self-reinforced nozzles included, for instance?
I don't want to tire you, thank you in advance, anyway.
