Hi,
Is there any summary keyword which displays average reservoir pressure after the simulation is completed? which of the following keyword is suitable?
1. FPR
2. FPRH
3. FPRP
Is there any other keyword except than the above ones?
Thanks in advance
Hi,
1. FPR
2. FPRH
3. FPRP
Thanks in advance
Use FPR, that's the field average simulated reservoir pressure (pore volume weighted average). Remember that this pressure is reported at the datum depth you defined in the SOLUTION section, so if you want to compare this with the observed/measured reservoir pressures, make sure they all are at the same datum.
