Results 1 to 12 of 12
Thread: Astm e18, e110, e164 e317, e570, e587
    Here are the Latest ASTM's
    ASTM E18 - Standard Test Methods for Rockwell Hardness of Metallic Materials
    ASTM E110 - Standard Test Method for Indentation Hardness of Metallic Materials by Portable Hardness Testers
    ASTM E164 - Standard Practice for Contact Ultrasonic Testing of Weldments
    ASTM E317- Standard Practice for Evaluating Performance Characteristics of Ultrasonic Pulse-Echo Testing Instruments and Systems without the Use of Electronic Measurement Instruments
    ASTM E570 - Standard Practice for Flux Leakage Examination of Ferromagnetic Steel Tubular Products
    ASTM E587 - Standard Practice for Ultrasonic Angle-Beam Contact Testing
  3. Re: Astm e18, e110, e164 e317, e570, e587
    Thanks engt
  5. Re: Astm e18, e110, e164 e317, e570, e587
    Thank you .
    thank alot
  9. Re: Astm e18, e110, e164 e317, e570, e587
    Gracias!!!
  10. Re: Astm e18, e110, e164 e317, e570, e587
    Those above links don't work anymore, pls upload those standards on another host. Thank a lot.
    That post is from 2013, that is why I prefer to post directly on the board. So people don't hound you years later to keep a file up.
    E18-15 Standard Test Methods for Rockwell Hardness of Metallic Materials
    E110-14 Standard Test Method for Rockwell and Brinell Hardness of Metallic Materials by Portable Hardness Testers
    E164-13 Standard Practice for Contact Ultrasonic Testing of Weldments
    E317-11 Standard Practice for Evaluating Performance Characteristics of Ultrasonic Pulse-Echo Testing Instruments and Systems without the Use of Electronic Measurement Instruments
    E570-15 Standard Practice for Flux Leakage Examination of Ferromagnetic Steel Tubular Products
    E587-10 Standard Practice for Ultrasonic Angle-Beam Contact Testing
  13. Re: Astm e18* e110* e164 e317* e570* e587
    Could you please share ASTM E18-17. Thanks.
  14. #11
    E18-17 3.01
    E18-17 redline
    Attached Files Attached Files
  16. Re: Astm e18, e110, e164 e317, e570, e587
    can you upload the following?
    e213, e309 and e273
  1. (Req) ASTM E10, ASTM E94, ASTM E140, ASTM E165, ASTM E709, EN 473
    By prasetyohse in forum Materials Science &Corrosion
    Last Post: 07-11-2019, 06:48 AM
  2. Replies: 13
  3. ASTM E317 required urgently
    By mohammed21 in forum Mechanical Engineering
    Last Post: 01-20-2018, 08:54 AM
  4. ASTM D5064 , ASTM D1730, ASTM D1731, ASTM D1732 are required!
    Last Post: 07-30-2012, 05:04 AM
  5. Request: ASTM E164
    Last Post: 11-16-2011, 04:28 PM
