Thread: Petrol storage tank installation material needed.
  1. Petrol storage tank installation material needed.
    Hello guys,
    I'm kind of very new for this section. I and my brother want to build 1000 tn Petrol Tank in our country. But i have no idea what a tank installaion is? is there anybody knows about this kind of project, please help us. I'm little bit knows about piping system.
    Thank you all!
    Re: Petrol storage tank installation material needed.
    Not sure quite what you are asking-- but will have go at it.
    Normally a fuel type storage tank will not need to be insulated. Here in the USA most refineries will only insulate storage tanks holding a HOT product (asphalt). A type of insulation will be installed around the tank on the walls and roof. The tank fabricators will weld on insulation rings or clips of some sort to help hold this insulation on.
    Depending on the location, the insulation will be in the range of about 2-3 inches in thickness.
    Hope this helps.
    Cheers
    LGW
    Hope this helps.
    Cheers
    LGW
  1. Above Ground Storage Tank by Myer needed urgently!
    By raja687 in forum Mechanical Engineering
    Last Post: 07-18-2011, 10:09 AM
