Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 25
Thread: BSI(British Standards Institution)
  1. Lightbulb BSI(British Standards Institution)
    38 5400-8 1978 Steel, Concrete and Composite Bridges Part 8: Recommendations for Materials and Workmanship: Concrete, Reinforcement and Prestressing Tendons
    39 5400-9.1 1983 Steel, concrete and composite bridges Part 9: Bridge bearings Section 9.1 Code of practice for design of bridge bearings
    40 5400-9.2 1983 Steel, Concrete and Composite Bridges Part 9: Bridge Bearings Section 9.2: Materials, Manufacture and Installation of Bridge Bearings
    41 5444 1977 Physical attributes of documents for microfilming or scanning
    42 5500 1994 Unfired Fusion Welded Pressure Vessels
    43 5536 1978 Preparation of Technical Drawings and Diagrams for Microfilming
    44 6364 1984 Valves for Cryogenic Service
    45 6387 1994 Specification for Performance Requirements for Cables Required to Maintain Circuit Integrity Under Fire Conditions
    46 6399-2 1995 Loading for Buildings - Part 2: Code of Practice for Wind Loads
    47 7121-1 1989 Code of practice for safe use of cranes
    48 7121-1 2006 Code of practice for safe use of cranes_Part 1: General
    49 7159 1989 Code of practice for Design and construction of glass reinforced plastics (GRP) piping systems for individual plants or sites
    50 7386 1997 Draughtstrips for the Draught Control of Existing Doors and Windows in Housing (Including Test Methods)
    51 7777-4 1993(R2007) Flat-Bottomed, Vertical, Cylindrical Storage Tanks for Low Temperature Service Part 4: Specification for the Design and Construction of Single Containment Tanks for the Storage of Liquid Oxygen, Liquid Nitrogen or Liquid Argon
    52 874 Part1 1986 Method for Determining Thermal Insulating Properties Part 1: Introduction, Definitions and Principles of Measurement
    53 CP102 1973 Protection of Buildings Against Water from the Ground
    54 EN 10216-2 2002 Seamless steel tubes for pressure purposes Technical delivery conditions Part 2: Non-alloy and alloy steel tubes with specified elevated temperature properties
    55 EN 10217-1 2002 Welded steel tubes for pressure purposes Technical delivery conditions Part 1: Non-alloy steel tubes with specified room temperature properties
    56 EN 10327(Withdrawn) 2004 Continuously hot-dip coated strip and sheet of low carbon steels for cold forming Technical delivery conditions
    57 EN 12324-3 1999 Irrigation techniques Reel machine systems
    58 EN 12811-1 2003 Temporary works equipment Part 1: Scaffolds Performance requirements and general design
    59 EN 12811-1 2003 Temporary works equipment Part 1: Scaffolds Performance requirements and general design
    60 EN 14 1995 Dimensions of bed blankets
    61 EN 15129 2009 Anti-seismic devices
    62 EN 197-1 2000 Cement - Part 1: Composition, Specifications and Conformity Criteria for Common Cements - Incorporating Amendments
    63 EN 197-2 2000 Cement - Part 2: Conformity Evaluation
    64 EN 197-4 2004 Cement - Part 4: Composition, specifications and conformity criteria for low early strength blastfurnace cements
    65 EN 1991-1-1 2002 Eurocode 1: Actions on structures - Part 1-1: General actions - Densities, self-weight, imposed loads for buildings - Incorporating corrigendum March 2009
    66 EN 1991-1-2 2002 Eurocode 1: Actions on structures - Part 1-2: General actions - Actions on structures exposed to fire
    67 EN 1991-1-2 2002 Eurocode 1: Actions on structures - Part 1-2: General actions - Actions on structures exposed to fire
    68 EN 1991-2-1 1995 Eurocode 1: Actions on structures_Part 2-1: General actions Actions on structures exposed to fire
    69 EN 1991-2-2 1995 Eurocode 1: Actions on structures_Part 2-2: General actions Actions on structures exposed to fire - Supersedes
    70 EN 1991-2-3 1995 Eurocode 1 Actions on structures_Part 2-3: General actions Snow loads
    71 EN 1991-2-4 1995 Eurocode 1: Actions on structures_Part 2-4: Actions on structures, Wind actions
    72 EN 1991-3 1995 Eurocode 1 Actions on structures Part 3: Actions induced by cranes and machinery
    73 EN 1992-1-1 1991 Eurocode 2: Design of concrete
    74 EN 1992-2 2001 Eurocode 2 Design of concrete structures_Part 2: Concrete bridges Design and detailing rules
    75 EN 1993-1-1 1993 Eurocode 3: Design of steel structures_Part 1-1: General rules and rules for buildings
    76 EN 1993-1-3 1996 Eurocode 3 Design of steel structures_Part 1-3: General rules Supplementary rules for cold-formed members and sheeting
    77 EN 1993-1-8 2005 Eurocode 3: Design of steel structures_Part 1-8: Design of joints
    78 EN 1993-2 2006 Eurocode 3: Design of steel structures_Part 2: Steel bridges
    79 EN 1994-1-1 1992 Eurocode 4 - Design of composite steel and concrete structures_Part 1-1 : general rules and rules for buildings
    80 EN 1994-1-2 1994 Eurocode 4 - Design of composite steel and concrete structures_Part 1-2 : general - Structural fire design
    81 EN 1997-1 2004 Eurocode 7: Geotechnical design_Part 1: General rules
    82 EN 1998-1-1 1996 Eurocode 8: Design of structures for earthquake resistance Part 1.1: General rules, seismic actions and rules for buildings
    83 EN 1998-1-2 1996 Eurocode 8: Design of structures for earthquake resistance_Part 2: Bridges
    84 EN 1998-4 1999 Eurocode 8: Design of structures for earthquake resistance Part 4: Silos, tanks and pipelines
    85 EN 1998-5 1996 Eurocode 8: Design of structures for earthquake resistance_Part 5: Foundations, retaining structures and geotechnical aspects
    86 EN 288-1 1992 Specification and Approval of Welding Procedures for Metallic Materials Part 1: General Rules for Fusion Welding
    87 EN 288-2 1992 Specification and Approval of Welding Procedures for Metallic Materials Part 2: Welding Procedure Specification for Arc Welding
    88 EN 288-3 1992 Specification and Approval of Welding Procedures for Metallic Materials Part 3: Welding Procedure Tests for the Arc Welding of Steels
    89 EN 288-4 1992 Specification and Approval of Welding Procedures for Metallic Materials Part 4: Welding Procedure Tests for the Arc Welding of Aluminium and its Alloys
    90 EN 3-9 2006 Portable fire extinguishers
    91 EN 30-1-1 2008 Domestic cooking appliances burning gas
    92 EN 30-1-2 1999 Domestic cooking appliances burning gas
    93 EN 30-1-3 2003 Domestic cooking appliances burning gas
    94 EN 440(Withdrawn) 1995 Welding Consumables - Wire Electrodes and Deposits for Gas Shielded Metal Arc Welding of Non Alloy and Fine Grain Steels
    95 EN 50020 2002 Electrical apparatus for potentially explosive atmospheres Intrinsic safety ‘i’
    96 EN 593 2004 Industrial Valves - Metallic Butterfly Valves
    97 EN 60034-9 2005 Rotating electrical machines Part 9: Noise limits
    98 EN 823 1995 Thermal Insulating Products for Building Applications - Determination of Thickness
    99 EN ISO 13857 2008 Safety of machinery: Safety distances to prevent hazard zones being reached by upper and lower limbs
    100 EN ISO 140-5 1998 Acoustics - Measurement of Sound Insulation in Buildings and of Building Elements_Part 5: Field Measurements of Airbourne Sound Insulation of Facade Elements and Facades
    101 EN ISO 14341 2008 Welding consumables ?Wire electrodes and deposits for gas shielded metal arc welding of non alloy and fine grain steels ?Classification
    102 EN ISO 1461 1999 Hot Dip Galvanized Coatings on Fabricated Iron and Steel Articles
    103 EN13080 2002 Agricultural machinery Manure spreaders Environmental protection Requirements and test methods
    104 NQA-1 2009 Quality Assurance Requirements for Nuclear Facility Applications - Includes Interpretations 1991 through November 2008
    105 NQA-1 2008 Quality Assurance Requirements for Nuclear Facility Applications - Includes Interpretations 1991 through November 2008
    106 PD 970 2005 Wrought Steels for Mechanical and Allied Engineering Purposes
    Re: BSI(British Standards Institution)
    Hi could you upload it again really I'll appreciate that
  5. Re: BSI(British Standards Institution)
    Please i need BS En 1834-1
  6. Re: BSI(British Standards Institution)
    please urgent i need standard BS 1387
    Can you upload standard EN 12811-1 again
    Quote Originally Posted by Marty Thompson View Post
    12811-1
    Thank You
    hi. in below link you can find some BS standards about 716 MB. maybe it will be helpful:
    link:
    files are showing but unable to download plz help, afetr 20 sec message comes link is not valid
    Jun 2008
    Karachi, Pakistan
    The BP Standards indexed at the site are in hundreds, but none is accessible, probably deleted
  14. Re: BSI(British Standards Institution)
    Quote Originally Posted by mohamad3010 View Post
    link:
    just tried, mohamad3010.
    the files can't be downloaded at all.
  16. Re: BSI(British Standards Institution)
    oh.
    found a solution to it.
    guys, please delete ".websearch" from the link.
  1. British standards needed
    By dso in forum Mechanical Engineering
    Last Post: 05-27-2024, 07:44 AM
  2. British Standards
    By cag in forum Electrical & Power Engineering
    Last Post: 05-08-2024, 03:38 PM
  3. help with British standards
    By mr_296 in forum Engineering Certificates
    Last Post: 11-04-2015, 02:14 PM
  4. Institution of Lighting Engineers (UK) - ILE TR7 design guidance
    By Duke01 in forum Civil & Structural Engineering
    Last Post: 05-22-2014, 02:09 PM
  5. British Standard EN 545
    By luqman in forum Pipeline And Fluid Flow
    Last Post: 03-17-2011, 05:48 AM
