1 Pigments for Portland Cement and Portland Cement Products
2 1109 1943 Specification for Cold forged mild steel rivets for cold closing
3 1243(Withdrawn) 1978 Metal Ties for Cavity Wall Construction
4 1245 1975 Metal Door Frames (Steel)
5 1706 1990 Electroplated Coatings of Zinc and Cadmium on Iron and Steel
6 1881-101 1983 Testing Concrete Part 101: Method of Sampling Fresh Concrete on Site
7 1881-5 1970 Methods of Testing Concrete Part 5: Methods of Testing Hardened Concrete for Other Than Strength
8 2494 1990 Elastomeric Seals for Joints in Pipework and Pipelines
9 2853 1957 Design and Testing of Steel Overhead Runway Beams
10 3799 1974 Specification for Steel Pipe Fittings, Screwed and Socket-Welding for the petroleum industry
11 4 Part1 1993 Structural Steel Sections: Part1. specification For Hot-rolled Sections
12 4210-1 1977 35 mm Microcopying of Technical Drawings Part 1: Operating Procedures
13 4210-2 1977 35 mm Microcopying of Technical Drawings Part 2: Photographic Requirements for Silver Film
14 4210-3 1977 35 mm Microcopying of Technical Drawings Part 3: Unitized Microfilm Carriers
15 4466(withdrawn) 1989 Scheduling, Dimensioning, Bending and Cutting of Steel Reinforcement for Concrete
16 4550-1 1978 Methods of Testing Cement Part 0: General Introduction
17 4550-3.1 1978 Methods of Testing Cement Part 3: Physical Tests Section 3.1: Introduction
18 4550-3.5 1978 Methods of Testing Cement Part 3: Physical Tests Section 3.5: Determination of Standard Consistence - AMD 1
19 4550-3.7 1978 Methods of Testing Cement Part 3: Physical Tests Section 3.7: Soundness Test - AMD 1
20 4550-4 1978 BS 4550 part4_1978
21 4550-6 1978 Methods of Testing Cement Part 6: Standard Sand for Mortar Cubes
22 466 1984 Power Driven Overhead Travelling Cranes Semi-Goliath and Goliath Cranes for General Use
23 4800 1989 Paint Colours for Building Purposes
24 4848 PART 2 1991 Hot-Rolled Structural Steel Sections Part 2: Specification for Hot-Finished Hollow Sections
25 4848 PART 4 1972 Hot-Rolled Structural Steel Sections Part 4: Equal and Unequal Angles
26 4848 PART 5 1980 Hot-Rolled Structural Steel Sections Part 5: Bulb Flats
27 4882 2006 Bolting for Flanges and Pressure Containing Purposes
28 5000 1981 Specification for Rotating Electrical Machines of Particular Types or for Particular Applications Ge
29 5308-1 1986 Instrumentation Cables Part 1: Specification for Polyethylene Insulated Cables
30 5308-2 1986 Instrumentation Cables - Part 2: Specification for PVC Insulated Cables
31 5400-1 1988 Steel, concrete and composite bridges - Part 1: General statement
32 5400-10 1980 Steel, Concrete and Composite Bridges
33 5400-2 1978 Steel, Concrete and Composite Bridges Part 2: Specification for Loads
34 5400-4 1990 Steel, Concrete and Composite Bridges Part 4: Code of Practice for Design of Concrete Bridges
35 5400-5 1979 Steel, concrete and composite bridges Part 5: Code of practice for the design of composite bridges
36 5400-6 1980 Steel, concrete and composite bridges Part 6: Specification for materials and workmanship, steel
