Results 1 to 6 of 6
Thread: MSS(Manufacturers Standardization Society of the Valve and Fittings Industry)
  1. Red face MSS(Manufacturers Standardization Society of the Valve and Fittings Industry)
    StandardNo. Year Title
    1 SP-127 2001 Bracing for Piping Systems Seismic - Wind - Dynamic Design, Selection, Application
    2 SP-25 1998 Standard Marking System for Valves, Fittings, Flanges, and Unions
    3 SP-42 2004 Corrosion Resistant Gate, Globe, Angle and Check Valves with Flanged and Butt Weld Ends (Classes 150, 300 & 600)
    4 SP-44 2010 Steel Pipeline Flanges
    5 SP-45 2003 Bypass and Drain Connections
    6 SP-53 2007 Quality Standard for Steel Castings and Forgings for Valves, Flanges, and Fittings and Other Piping Components - Magnetic Particle Examination Method
    7 SP-54 2007 Quality Standard for Steel Castings and Forgings for Valves, Flanges, and Fittings and Other Piping Components - Radiographic Examination Method
    8 SP-55 2006 Quality Standard for Steel Castings for Valves, Flanges, Fittings and Other Piping Components - Visual Method for Evaluation of Surface Irregularities
    9 SP-58 2009 Pipe Hangers and Supports � Materials, Design, Manufacture, Selection, Application, and Installation
    10 SP-58 2002 Pipe Hangers and Supports - Materials, Design and Manufacture
    11 SP-61 2003 Pressure Testing of Valves
    12 SP-67 2002 Butterfly Valves
    13 SP-68 1997 High Pressure Butterfly Valves with Offset Design
    14 SP-69 2003 Pipe Hangers and Supports - Selection and Application
    15 SP-72 2008 Ball Valves with Flanged or Butt-Welding Ends for General Service
    16 SP-75 2008 Specification for High-Test, Wrought, Butt-Welding Fittings
    17 SP-80 2008 Bronze Gate, Globe, Angle, and Check Valves
    18 SP-81 1995 Stainless Steel, Bonnetless, Flanged Knife Gate Valves
    19 SP-81 2006 Stainless Steel, Bonnetless, Flanged Knife Gate Valves
    20 SP-85 2002 Gray Iron Globe & Angle Valves, Flanged and Threaded Ends
    21 SP-88 2010 Diaphragm Valves
    22 SP-89 2003 Pipe Hangers and Supports - Fabrication and Installation Practices
    23 SP-9 2001 Spot Facing for Bronze, Iron and Steel Flanges
    24 SP-93 2004 Quality Standard for Steel Castings and Forgings for Valves, Flanges, Fittings, and Other Piping Components Liquid Penetrant Examination Method
    25 SP-94 2004 Quality Standard for Ferritic and Martensitic Steel Castings for Valves, Flanges, Fittings, and Other Piping Components Ultrasonic Examination Method
    26 SP-95 2006 Swage(d) Nipples and Bull Plugs
    27 SP-97 2006 Integrally Reinforced Forged Branch Outlet Fittings - Socket Welding, Threaded and Buttwelding Ends
  3. Re: MSS(Manufacturers Standardization Society of the Valve and Fittings Industry)
    It's not available =(
  5. Re: MSS(Manufacturers Standardization Society of the Valve and Fittings Industry)
    plz send me stoage link where I can store 4shaerd deleted all my material say copyright material. plz help me
  6. Re: MSS(Manufacturers Standardization Society of the Valve and Fittings Industry)
  7. Re: MSS(Manufacturers Standardization Society of the Valve and Fittings Industry)
    thanks!!
  9. Re: MSS(Manufacturers Standardization Society of the Valve and Fittings Industry)
    Thanks a lot!!!!!!!
  1. Replies: 3
    Last Post: 11-05-2014, 05:45 PM
  2. Replies: 2
    Last Post: 11-03-2014, 10:54 PM
  3. DIN - the German Institute for Standardization
    By Esam in forum Pipeline And Fluid Flow
    Last Post: 09-05-2011, 03:17 PM
  4. Manufacturers Standardization Society Standards
    By sudharshanan in forum Oil And Gas Process
    Last Post: 11-19-2008, 02:27 PM
