if u need any one plz let me know
[ ASME ] 569 Hits
No. StandardNo. Year Title
1 A112.1.2 2004 Air Gaps in Plumbing Systems (For Plumbing Fixtures and Water-Connected Receptors)
2 A112.1.3 2000 Air Gap Fittings for Use with Plumbing Fixtures, Appliances, and Appurtenances
3 A112.14.1 2003 Backwater Valves
4 A112.14.3 2004 Grease Interceptors
5 A112.14.4 2001 Grease Removal Devices
6 A112.14.6 2006 FOG (Fats, Oils, and Greases) Disposal Systems
7 A112.18.1 2005 Plumbing Fixture Waste Fittings
8 A112.18.2 2005 Plumbing Fixture Waste Fittings
9 A112.18.3 2002 Performance Requirements for Backflow Protection Devices and Systems in Plumbing Fixture Fittings
10 A112.18.6 2003 Flexible Water Connectors
11 A112.18.7 2004 Deck Mounted Bath/Shower Transfer Valves with Integral Backflow Protection
12 A112.19.10 2003 Dual Flush Devices for Water Closets
13 A112.19.12 2004 Wall Mounted,Pedestal Mounted,Adjustable, Elevating, Tilting, and Pivoting Lavatory, Sink, and Shampoo Bowl Carrier Systems and Drain Waste Systems
14 A112.19.13 2001 Electrohydraulic Water Closets
15 A112.19.14 2006 Six-Liter Water Closets Equipped with Dual Flushing Device
16 A112.19.15 2005 Bathtubs/Whirlpool Bathtubs with Pressure Sealed Doors
17 A112.19.16 2006 Bathtubs/Whirlpool Bathtubs with Pressure Sealed Doors
18 A112.19.17 2002 Manfactured Safety Vacuum Release Systems (SVRS) for Residential and Commercial Swimming Pool, Spa, Hot Tub, and Wading Pool Suction Systems
19 A112.19.19 2006 Vitreous China Nonwater Urinals
20 A112.19.1M 2004 Enameled Cast Iron Plumbing Fixtures-Errata - November 1996; Supplement 2 - June 2000
21 A112.19.2 2003 Vitreous China Plumbing Fixtures and Hydraulic Requirements for Water Closets and Urinals-Revision and Consolidation of ASME A112.19.2M and ASME A112.19.6
22 A112.19.3 2004 Stainless Steel Plumbing Fixtures (Designed for Residential Use)-Supplement: September 2002
23 A112.19.4M 2004 Porcelain Enameled Formed Steel Plumbing Fixtures-Errata - November 1996; Supplement 1 - 1998; Supplement 2 - June 2000
24 A112.19.5 2005 Trim for Water-Closet Bowls, Tanks, and Urinals
25 A112.19.6 1995 Hydraulic Performance Requirements for Water Closets and Urinals-Included in A112.19.2-2003
26 A112.19.7 2006 Hydromassage Bathtub Appliances
27 A112.19.8M 1996 Suction Fittings for Use in Swimming Pools, Wading Pools, Spas, and Hot Tubs
28 A112.19.9M 2002 Non-Vitreous Ceramic Plumbing Fixtures-Supplement 1: 2002
29 A112.20.1 2004 Qualification of Installers of High Purity Piping Systems
30 A112.20.2 2004 Qualification of Installers of Firestop Systems and Devices for Piping Systems
31 A112.21.2M 1983 Roof Drains-Revision of ANSI A112.21.2-1971
32 A112.21.3 2001 Hydrants for Utility and Maintenance Use-Revision of ANSI A112.21.3-1976
33 A112.3.1 1993 Performance Standard and Installation Procedures for Stainless Steel Drainage Systems for Sanitary, Storm, and Chemical Applications, Above and Below Ground
34 A112.3.4 2004 Macerating Toilet Systems and Related Components
35 A112.36.2M 2002 Cleanouts
36 A112.4.1 2002 Water Heater Relief Valve Drain Tubes
37 A112.4.14 2004 Manually Operated, Quarter-Turn Shutoff Valves for Use in Plumbing Systems
38 A112.4.2 2003 Water Closet Personal Hygiene Devices
39 A112.4.3 2004 Plastic Fittings for Connecting Water Closets to the Sanitary Drainage System
40 A112.4.7 2002 Point of Use and Branch Water Submetering Systems
41 A112.6.1M 2002 Floor-Affixed Supports for Off-the-Floor Plumbing Fixtures for Public Use
42 A112.6.2 2004 Framing-Affixed Supports for Off-the-Floor Water Closets with Concealed Tanks
43 A112.6.3 2007 Floor Drains and Trench Drains
44 A112.6.4 2003 Roof, Deck, and Balcony Drains
45 A112.6.7 2007 Enameled and Epoxy Coated Cast Iron and PVC Platic Sanitary Floor Sinks
46 A112.6.9 2005 Siphonic Roof Drains
47 A120.1 2006 Safety Requirements for Powered Platforms and Traveling Ladders and Gantries for Building Maintenance
48 A13.1 2007 Scheme for the Identification of Piping Systems
49 A17.1 2007 Safety Code for Elevators and Escalators Includes Requirements for Elevators, Escalators, Dumbwaiters, Moving Walks, Material Lifts, and Dumbwaiters With Automatic Transfer Devices
50 A17.1 HDBK 2004 Safety Code for Elevators and Escalators
51 A17.1 INTERPRETATIONS 2002 Interpretations to A17.1-2003 Safety Code for Elevators and Escalators-Includes Interpretations No. 25 through 28
52 A17.2 2004 Guide for Inspection of Elevators, Escalators, and Moving Walks
53 A17.2.3 1998 Inspectors' Manual for Escalators and Moving Walks Includes Inspection Procedures for Escalators and Moving Walks-Addenda A - 8/10/2000
54 A17.3 2005 Safety Code for Existing Elevators and Escalators-Interpretations No. 6
55 A17.3 INTERPRETATIONS 2003 Interpretations to A17.3-1996 Safety Code for Existing Elevators and Escalators-Includes Interpretations No. 1 Through 6
56 A17.4 1999 Guide for Emergency Personnel (Includes Evacuation Procedures and Firefighters´ Service Operating Procedures)-Errata 9/2002
57 A17.5 2004 Elevator and Escalator Electrical Equipment-CAN/CSA-B44.1-2004
58 A17.7 2007 Performance-based safety code for elevators and escalators-first edition : [Ready]
59 A18.1 2005 Safety Standard for Platform Lifts and Stairway Chairlifts-Incorporating Errata: 04/2006
60 A90.1 2003 Safety Standard for Belt Manlifts : [Ready]
61 A90.1 INTERPRETATIONS 1999 Interpretations to ASME A90.1-1997
62 AG-1 2003 Code on Nuclear Air and Gas Treatment-Errata: 02/04; Addenda: 09/30/05
63 AS-11 2002 Personnel of Codes, Standards, and Related Conformity Assessment Committees
64 B1 TECH REPT 1993 Measurement Uncertainty for 60 Deg. Screw Thread Gage Element Measurement (Inch and Metric)
65 B1.1 2003 Unified Inch Screw Threads (UN and UNR Thread Form)
66 B1.10M 2004 Unified Miniature Screw Threads
67 B1.11 2006 Microscope Objective Thread-Errata - July 1972
68 B1.12 2003 Class 5 Interference-Fit Thread
69 B1.13M 2005 Metric Screw Threads: M Profile
70 B1.15 1995 Unified Inch Screw Threads (UNJ Thread Form)
71 B1.16M 2006 Gages and Gaging for Metric M Screw Threads-Revision of ANSI B1.16-1972
72 B1.2 2007 Gages and Gaging for Unified Inch Screw Threads-Errata May 1992
73 B1.20.1 2006 Pipe Threads, General Purpose (Inch)-Revision and Redesignation of ASME/ANSI B2.1-1968
74 B1.20.3 2003 Dryseal Pipe Threads (Inch)-Revision and Redesignation of B2.2-1968
75 B1.20.5 2004 Gaging for Dryseal Pipe Threads (Inch)
76 B1.20.7 2003 Hose Coupling Screw Threads (Inch)
77 B1.21M 1997 Metric Screw Threads: MJ Profile
78 B1.22M 2006 Gages and Gaging for MJ Series Metric Screw Threads-Revision of ANSI B1.22-1978
79 B1.30 2002 Screw Threads: Standard Practice for Calculating and Rounding Dimensions
80 B1.3M 2001 Screw Thread Gaging Systems for Dimensional Acceptability - Inch and Metric Screw Threads (UN, UNR, UNJ, M, and MJ)-Errata - 1994
81 B1.5 2004 Acme Screw Threads
82 B1.7M 2006 Screw Threads: Nomenclature, Definitions, and Letter Symbols-Revision of ANSI B1.7M-1984
83 B1.8 2006 Stub Acme Screw Threads
84 B1.8 2006 Stub Acme Screw Threads : [Ready]
85 B1.9 2001 Buttress Inch Screw Threads 7 Degrees/45 Degrees Form with 0.6 Pitch Basic Height of Thread Engagement
86 B1.9 2007 Buttress Inch Screw Threads 7 Degrees/45 Degrees Form with 0.6 Pitch Basic Height of Thread Engagement
87 B107.1 2002 Socket Wrenches, Hand (Inch Series)
88 B107.10 2005 Handles and Attachments for Hand Socket Wrenches
89 B107.100 2002 Wrenches-Incorporating B107.6, B107.9, B107.39 and B107.40
90 B107.11 2002 Pliers: Diagonal Cutting, and Nippers, End Cutting
91 B107.12 2004 Nut Drivers
92 B107.13 2003 Pliers - Long Nose, Long Reach
93 B107.14 2004 Hand Torque Tools (Mechanical)
94 B107.15 2002 Flat Tip Screwdrivers
95 B107.16M 2004 Shears (Metal Cutting, Hand)
96 B107.17M 1997 Gages, Wrench Openings, Reference
97 B107.18 2003 Pliers: Wire Twister
98 B107.19 2004 Pliers, Retaining Ring
99 B107.2 2002 Socket Wrenches, Extensions, Adaptors, and Universal Joints, Power Drive (Impact) (Inch Series)
100 B107.20 2004 Pliers: Lineman's, Iron Worker's, Gas, Glass, Fence, and Battery
101 B107.21 2005 Wrench, Crowfoot
102 B107.22M 2004 Electronic Cutters-Errata - May 1999
103 B107.23M 2004 Pliers: Multiple Position, Adjustable
104 B107.24 2002 Locking Pliers
105 B107.25 2002 Pliers: Performance Test Methods
106 B107.27 2003 Pliers: Multiple Position, Electrical Connector
107 B107.28 2005 Electronic Torque Instruments
108 B107.29 2005 Electronic Tester, Hand Torque Tools
109 B107.30 2002 Cross Tip Screwdrivers
110 B107.31M 1997 Screwdrivers, Cross Tip Gaging
111 B107.33M 2002 Socket Wrenches, Impact (Metric Series)
112 B107.34 2003 Socket Wrenches for Spark Plugs
113 B107.36 2002 Pliers: Locking, Clamp, and Tubing Pinch-Off
114 B107.37 2003 Pliers: Wire Cutters/Strippers
115 B107.38M 2004 Electronic Pliers
116 B107.4 2005 Driving and Spindle Ends for Portable Hand, Impact, Air, and Electric Tools (Percussion Tools Excluded)
117 B107.41 2004 Nail Hammers - Safety Requirements
118 B107.42M 2004 Hatchets: Safety Requirements
119 B107.43 2002 Wood-Splitting Wedges
120 B107.44 2002 Glaziers´ Chisels and Wood Chisels
121 B107.45 2002 Ripping Chisels and Flooring/Electricians´ Chisels
122 B107.46 1998 Stud, Screw, and Pipe Extractors: Safety Requirements
123 B107.47M 1998 Metal Chisels: Safety Requirements
124 B107.48 2005 Metal Chisels, Punches, and Drift Pins
125 B107.49 2004 Nail Sets
126 B107.50M 1998 Brick Chisels and Brick Sets: Safety Requirements
127 B107.51 2001 Star Drills: Safety Requirements
128 B107.52M 1998 Nail-Puller Bars: Safety Requirements
129 B107.53 2004 Ball Peen Hammers: Safety Requirements
130 B107.54 2001 Heavy Striking Tools: Safety Requirements
131 B107.55 2002 Axes: Safety Requirements
132 B107.56 2005 Body Repair Hammers and Dolly Blocks: Safety Requirements-Formerly ANSI/HTI B173.5-1991
133 B107.57 2005 Bricklayers’ Hammers and Prospecting Picks
134 B107.58M 2005 Riveting, Scaling, and Tinner's Setting Hammers: Safety Requirements
135 B107.59 2002 Slugging and Striking Wrenches
136 B107.5M 2002 Socket Wrenches, Hand (Metric Series)
137 B107.5M 2002 Socket Wrenches, Hand (Metric Series)
138 B107.60 200 Pry Bars
139 B107.8 2003 Adjustable Wrenches-Replaces ASME B107.8M
140 B133.12 2001 Procurement Standard for Gas Turbine Maintenance and Safety
141 B133.12 2001 Procurement Standard for Gas Turbine Maintenance and Safety
142 B133.16 2000 Procurement Standard for Gas Turbine Marine Applications
143 B133.16 2000 Procurement Standard for Gas Turbine Marine Applications
144 B133.5 1997 Procurement Standard for Gas Turbine Electrical Equipment
145 B133.5 1997 Procurement Standard for Gas Turbine Electrical Equipment
146 B133.7M 2001 Gas Turbine Fuels - Revision of ANSI B133.7-1977; Out of Print
147 B133.8 2001 Gas Turbine Installation Sound Emissions
148 B133.9 2001 Measurement of Exhaust Emissions from Stationary Gas Turbine Engines-Revision of ANSI B133.9-1979
149 B16.1 2005 Gray Iron Pipe Flanges and Flanged Fittings (Classes 25, 125, and 250)
150 B16.10 2003 Dehumudification and Temperature Control During Surface Preparation, Application, and Curing for Coatings/Linings of Steel Tanks, Vessels, and Other Enclosed Areas-SSPC TR-3:12 2000
151 B16.10 INTERPRETATIONS 1992 Interpretations to B16.10-1992 Face-to-Face and End-to-End Dimensions of Valves-Includes Interpretation No. 1
152 B16.11 2005 Forged Fittings, Socket-Welding and Threaded
153 B16.12 2006 Cast Iron Threaded Drainage Fittings
154 B16.14 1991 Ferrous Pipe Plugs, Bushings, and Locknuts with Pipe Threads
155 B16.15 2006 Cast Copper Alloy Threaded Fittings Classes 125 and 250
156 B16.15 INTERPRETATIONS 1985 Cast Copper Alloy Threaded Fittings Classes 125 and 250
157 B16.18 2005 Cast Copper Alloy Solder Joint Pressure Fittings
158 B16.20 2007 Metallic Gaskets for Pipe Flanges Ring-Joint, Spiral-Wound, and Jacketed
159 B16.20 2004 Metallic Gaskets for Pipe Flanges Ring-Joint, Spiral-Wound, and Jacketed-
160 B16.21 2005 Nonmetallic Flat Gaskets for Pipe Flanges
161 B16.22 2005 Wrought Copper and Copper Alloy Solder Joint Pressure Fittings
162 B16.23 2002 Cast Copper Alloy Solder Joint Drainage Fittings: DWV
163 B16.23 2006 Cast Copper Alloy Solder Joint Drainage Fittings: DWV - Errata:March 2003
164 B16.24 2001 Cast Copper Alloy Pipe Flanges and Flanged
165 B16.25 2003 Buttwelding Ends
166 B16.25 INTERPRETATIONS 1992 Interpretations to B16.25-1997 Buttwelding Ends-Includes Interpretation No. 1
167 B16.26 2006 Cast Copper Alloy Fittings for Flared Copper Tubes
168 B16.28 1994 Wrought Steel Buttwelding Short Radius Elbows and Returns
169 B16.28 INTERPRETATIONS 1993 Interpretations to B16.28-1994 Wrought Steel Buttwelding Short Radius Elbows and Returns-Includes Interpretations No. 1
170 B16.29 2001 Wrought Copper and Wrought Copper Alloy Solder Joint Drainage Fittings - DWV
171 B16.3 2006 Malleable Iron Threaded Fittings Classes 150 and 300
172 B16.33 2002 Manually Operated Metallic Gas Valves for Use in Gas Piping Systems up to 125 PSI (Sizes NPS 1/2 Through NPS 2)
173 B16.34 2004 Valves - Flanged, Threaded, and Welding End-Addenda A
174 B16.34 2009 Valves- Flanged, Threaded, and Welding End
175 B16.34 INTERPRETATIONS 1998 Interpretations to B16.34-1996 Valves - Flanged, Threaded, and Welding End-Includes Interpretation No. 2
176 B16.36 1996 Orifice Flanges
177 B16.36 INTERPRETATIONS 1995 Interpretations to B16.36-1996 Orifice Flanges
178 B16.38 2005 Large Metallic Valves for Gas Distribution (Manually Operated, NPS 2 1/2 to 12, 125 psig Maximum)
179 B16.39 2006 Malleable Iron Threaded Pipe Unions Classes 150, 250, and 300
180 B16.4 2006 Gray Iron Threaded Fittings Classes 125 and 250
181 B16.4 INTERPRETATIONS 1998 Interpretations to B16.4-1998 - Gray Iron Threaded Fittings - Classes 125 and 250
182 B16.40 2002 Manually Operated Thermoplastic Gas Shutoffs and Valves in Gas Distribution Systems-Erratum: July 2003 now incorporated (pg 'v')
183 B16.42 2006 Ductile Iron Pipe Flanges and Flanged Fittings Classes 150 and 300
184 B16.44 2002 Manually Operated Metallic Gas Valves for Use in Aboveground Piping Systems up to 5 PSI
185 B16.45 2006 Cast Iron Fittings for Sovent Drainage Systems
186 B16.47 2006 Large Diameter Steel Flanges NPS 26 Through NPS 60 Metric/Inch Standard
187 B16.47 1996 Large Diameter Steel Flanges NPS 26 Through NPS 60-
188 B16.47 INTERPRETATIONS 1995 Interpretations to B16.47-1996 Large Diameter Steel Flanges NPS 26 Through NPS 60
189 B16.48 2005 Line Blanks
190 B16.49 2000 Factory-Made Wrought Steel Buttwelding Induction Bends for Transportation and Distribution Systems
191 B16.49 2000 Factory-Made Wrought Steel Buttwelding Induction Bends for Transportation and Distribution Systems
192 B16.5 2009 Pipe Flanges and Flanged Fittings NPS 1/2 Through NPS 24 Metric/Inch Standard
193 B16.5 2003 Pipe Flanges and Flanged Fittings NPS 1/2 Through NPS 24 Metric/Inch Standard-Revision of ASME B16.5-1996
194 B16.5 INTERPRETATIONS 1997 Interpretations to B16.5-1996 Pipe Flanges and Flanged Fittings-Includes Interpretation No. 3
195 B16.50 2001 Wrought Copper and Copper Alloy Braze-Joint Pressure Fittings
196 B16.9 2003 Factory-made wrought buttwelding fittings
197 B16.9 INTERPRETATIONS 1992 Interpretations to B16.9-1993 Factory-Made Wrought Steel Buttwelding Fittings-Includes Interpretation No. 1
198 B17.1 2003 Keys and Keyseats
199 B17.2 2003 Woodruff Keys and Keyseats-Revision of USAS B17F-1930
200 B18.1.1 2006 Small Solid Rivets 7/16 Inch Nominal Diameter and Smaller : [Ready]
201 B18.1.2 2006 Large Rivets 1/2 Inch Nominal Diameter and Larger-Revision of B18.4-1960 : [Ready]
202 B18.1.3M 2006 Metric Small Solid Rivets 12 mm Nominal Diameter and Smaller-Errata - October 1985 : [Ready]
203 B18.10 2006 Track Bolts and Nuts
204 B18.11 2005 Miniature Screws
205 B18.12 2006 Glossary of Terms for Mechanical Fasteners
206 B18.13 2003 Screw and Washer Assemblies - Sems (Inch Series)
207 B18.13.1M 2003 Screw and Washer Assemblies - Sems (Metric Series)
208 B18.15 2003 Forged Eyebolts
209 B18.16M 2004 Prevailing-Torque Type Steel Metric Hex Nuts and Hex Flange Nuts
210 B18.18.1 2005 Inspection and Quality Assurance for General Purpose Fasteners
211 B18.18.2M 2005 Inspection and Quality Assurance for High-Volume Machine Assembly Fasteners
212 B18.18.3M 2005 Inspection and Quality Assurance for Special Purpose Fasteners
213 B18.18.4M 2005 Inspection and Quality Assurance for Fasteners for Highly Specialized Engineered Applications
214 B18.18.5M 2003 Inspection and Quality Assurance Plan Requiring In-Process Inspection and Controls
215 B18.18.6M 2003 Quality Assurance Plan for Fasteners Produced in a Third Party Accreditation System
216 B18.18.7M 2003 Quality Assurance Plan for Fasteners Produced in a Customer Approved Control Plan
217 B18.2.1 1998 Square and Hex Bolts and Screws (Inch Series)-Addenda A
218 B18.2.1 2005 Square and Hex Bolts and Screws (Inch Series)-Addenda A - 10/08/1999; Erratum July 2003 : [Ready]
219 B18.2.1 2010 Square, Hex, Heavy Hex, and Askew Head Bolts and Hex, Heavy Hex, Hex Flange, Lobed Head, and Lag Screws
220 B18.2.2 1998 Square and Hex Nuts (Inch Series)
221 B18.2.2 2005 Square and Hex Nuts (Inch Series) : [Ready]
222 B18.2.3.10M 1996 Square Head Bolts(Metric series)
223 B18.2.3.1M 2005 Metric Hex Cap Screws : [Ready]
224 B18.2.3.2M 2005 Metric Formed Hex Screws
225 B18.2.3.3M 2001 Metric Heavy Hex Screws
226 B18.2.3.4M 2006 Metric Hex Flange Screws - Supersedes IFI 536:1982
227 B18.2.3.5M 2006 Metric Hex Bolts - Errata - May 1981
228 B18.2.3.6M 2006 Metric Heavy Hex Bolts - Errata - April 1981
229 B18.2.3.7M 2006 Metric Heavy Hex Structural Bolts - Errata - April 1981
230 B18.2.3.8M 2006 Metric Hex Lag Screws
231 B18.2.3.9M 2006 Metric Heavy Hex Flange Screws - Supersedes IFI 538:1982
232 B18.2.4.1M 2002 Metric Hex Nuts, Style 1
233 B18.2.4.2M 2005 Metric Hex Nuts, Style 2
234 B18.2.4.3M 2006 Metric Slotted Hex Nuts - Errata - May 1981
235 B18.2.4.4M 2005 Metric Hex Flange Nuts
236 B18.2.4.5M 2003 Metric Hex Jam Nuts
237 B18.2.4.6M 2003 Metric Heavy Hex Nuts
238 B18.2.6 2006 Fasteners for Use in Structural Applications
239 B18.2.7.1M 2002 Metric 12-Spline Flange Screws - Erratum 12/2002
240 B18.2.8 2005 Clearance Holes for Bolts, Screws, and Studs
241 B18.21.1 2005 Washers: Helical Spring-Lock, Tooth Lock, and Plain Washers (Inch Series)
242 B18.21.2M 2005 Lock Washers (Metric Series) - Supersedes IFI 532: 1982
243 B18.22M 2005 Metric Plain Washers
244 B18.24 2004 Part Identifying Number (PIN) Code System Standard for B18 Fastener Products - Supersedes ASME B18.24.1, B18.24.2, and B18.24.3
245 B18.25.1M 2003 Square and Rectangular Keys and Keyways
246 B18.25.2M 2003 Woodruff Keys and Keyways
247 B18.25.3M 2003 Square and Rectangular Keys and Keyways: Width Tolerances and Deviations Greater than Basic Size
248 B18.27 1998 Tapered and Reduced Cross Section Retaining Rings (Inch Series)
249 B18.29.1 2002 Helical Coil Screw Thread Inserts - Free Running and Screw Locking (Inch Series)
250 B18.29.2M 2005 Helical Coil Screw Thread Inserts: Free Running and Screw Locking (Metric Series)
251 B18.3 2003 Socket Cap, Shoulder, and Set Screws, Hex and Spline Keys (Inch Series)
252 B18.3.1M 2002 Clearance Holes for Bolts, Screws, and Studs
253 B18.3.2M 2003 Metric Series Hexagon Keys and Bits
254 B18.3.3M 2002 Hexagon Socket Head Shoulder Screws (Metric Series)
255 B18.3.4M 2002 Hexagon Socket Button Head Cap Screws (Metric Series)
256 B18.3.5M 2002 Hexagon Socket Flat Countersunk Head Cap Screws (Metric Series)
257 B18.3.6M 2002 Metric Series Socket Set Screws
258 B18.30.1M 2005 Open-End Blind Rivets with Break Mandrels (Metric Series)
259 B18.31.1M 2005 Metric Continuous and Double-End Studs
260 B18.5 2003 Round Head Bolts (Inch Series)
261 B18.5.2.1M 2006 Metric Round Head Short Square Neck Bolts
262 B18.5.2.2M 2005 Metric Round Head Square Neck Bolts
263 B18.5.2.3M 2003 Round Head Square Neck Bolts with large head(Metric series)
264 B18.6.1 1997 Wood Screws (Inch Series)
265 B18.6.2 2005 Slotted Head Cap Screws, Square Head Set Screws, and Slotted Headless Set Screws (Inch Series)
266 B18.6.3 2003 Machine Screws and Machine Screw Nuts
267 B18.6.4 2005 Thread Forming and Thread Cutting Tapping Screws and Metallic Drive Screws (Inch Series)
268 B18.6.5M 2005 Metric Thread-Forming and Thread-Cutting Tapping Screws - 2000 Edition; Revision of ANSI/ASME B18.6.5M-1986
269 B18.6.7M 2005 Metric Machine Screws - Supersedes IFI 513: 1981
270 B18.7 2001 General Purpose Semi-Tubular Rivets, Full Tubular Rivets, Split Rivets and End Caps
271 B18.7.1M 2005 Metric General Purpose Semi-Tubular Rivets
272 B18.8.100M 2005 Spring Pins: Coiled Type, Spring Pins: Slotted, Machine Dowel Pins: Hardened Ground, and Grooved Pins - Metric Series; Incorporating ASME B18.8.3M, B18.8.4M, B18.8.5M, and B18.8.9M
273 B18.8.2 2005 Taper Pins, Dowel Pins, Straight Pins, Grooved Pins, and Spring Pins (Inch Series)
274 B18.8.200M 2000 Cotter Pins, Headless Clevis Pins, and Headed Clevis Pins - Metric Series
275 B18.9 2003 Plow Bolts
276 B19.1 1995 Safety Standard for Air Compressor Systems
277 B19.3 1991 Safety Standard for Compressors for Process Industries
278 B20.1 2006 Safety Standard for Conveyors and Related Equipment
279 B27.6 2005 General Purpose Uniform Cross Section Spiral Retaining Rings
280 B27.7 2005 General Purpose Tapered and Reduced Cross Section Retaining Rings
281 B27.8M 2005 General Purpose Metric Tapered and Reduced Cross Section Retaining Rings Type 3DM1 - Heavy Duty External Rings Type 3EM1 - Reinforced "E" Rings Type 3FM1 - "C" Type Rings
282 B29.100 2002 Precision Power Transmission, Double-Pitch Power Transmission, and Double-Pitch Conveyor Roller Chains, Attachments, and Sprockets - Incorporating ASME B29.1, B29.3, and B29.4; Erratum 01/2004
283 B29.10M 2002 Heavy Duty Offset Sidebar Power Transmission Roller Chains and Sprocket Teeth
284 B29.12M 2004 Steel Bushed Rollerless Chains, Attachments, and Sprocket Teeth
285 B29.17M 2004 Hinge Type Flat Top Conveyor Chains and Sprocket Teeth
286 B29.200 2001 Welded-Steel-Type Mill Chains, Welded-Steel-Type Drag Chains, Attachments, and Sprocket Teeth - Incorporating ASME B29.16M and ASME B29.18M
287 B29.21M 2003 700 Class Welded Steel and Cast Chains, Attachments and Sprockets for Water and Sewage Treatment Plants
288 B29.22 2001 Drop Forged Rivetless Chains, Sprocket Teeth Drive Chain/Drive Dogs
289 B29.23M 2004 Flexible Chain Couplings
290 B29.24 2002 Roller Load Chains for Overhead Hoists
291 B29.26 2006 Fatigue Testing Power Transmission Roller Chain - Errata October 2002
292 B29.27 2002 Single-Pitch and Double-Pitch Hollow Pin Conveyer Chains and Attachments
293 B29.2M 2004 Inverted Tooth (Silent) Chains and Sprockets
294 B29.300 1998 Agricultural, Detachable, and Pintle Chains, Attachments, and Sprockets - Incorporating ASME B29.6, B29.19, and B29.25; Addenda A:2004
295 B29.400 2001 Combination, "H" Type Mill Chains, and Sprockets
296 B29.8 2002 Leaf Chains, Clevises, and Sheaves
297 B30.1 2004 Jacks, Industrial Rollers, Air Casters, and Hydraulic Gantries
298 B30.10 2005 Hooks - Safety Standard for Cableways, Cranes, Derricks, Hoists, Hooks, Jacks, and Slings
299 B30.10 INTERPRETATIONS 2003 Interpretations to B30.10-1993 Hooks
300 B30.11 2004 Monorails and Underhung Cranes
301 B30.11 INTERPRETATIONS 1999 Interpretations to B30.11 - 1998 Monorails and Underhung Cranes
302 B30.12 2006 Handling Loads Suspended from Rotorcraft
303 B30.13 2003 Storage/Retrieval (S/R) Machines and Associated Equipment
304 B30.13 INTERPRETATIONS 1998 Interpretations to B30.13-1996 Storage/Retrieval (S/R) Machines and Associated Equipment
305 B30.14 2004 Side Boom Tractors
306 B30.16 2003 Overhead Hoists (Underhung) Safety Standard for Cableways, Cranes, Derricks, Hoists, Hooks, Jacks, and Slings
307 B30.16 INTERPRETATIONS 1998 Interpretations to B30.16-1998 Overhead Hoists (Underhung)
308 B30.17 2006 Overhead and Gantry Cranes ( Top Running Bridge, Single Girder, Underhung Hoist)
309 B30.17 INTERPRETATIONS 1992 Interpretations to B30.17-1998 Overhead and Gantry Cranes (Top Running Bridge, Single Girder, Underhung Hoist)
310 B30.18 2004 Stacker Cranes (Top or Under Running Bridge, Multiple Girder with Top or Under Running Trolley Hoist)
311 B30.19 2005 Cableways
312 B30.2 2005 Overhead and Gantry Cranes (Top Running Bridge, Single or Multiple Girder, Top Running Trolley Hoist)
313 B30.2 INTERPRETATIONS 1997 Interpretations to B30.2-1996 Overhead and Gantry Cranes Top Running Bridge, Single or Multiple Girder, Top Running Trolley Hoist - Includes Interpretation No. 1 Through 3
314 B30.20 2006 Below-the-Hook Lifting Devices
315 B30.20 INTERPRETATIONS 1997 Interpretations to B30.20 - Below-The-Hook Lifting Devices
316 B30.21 2005 Manually Lever Operated Hoists
317 B30.21 INTERPRETATIONS 1992 Interpretations to B30.2-1994 Manually Lever Operated Hoists
318 B30.22 2005 Articulating Boom Cranes
319 B30.22 INTERPRETATIONS 1997 Interpretations to B30.22-1993 Articulating Boom Cranes
320 B30.23 2005 Personnel Lifting Systems Safety Standard for Cableways, Cranes, Derricks, Hoists, Hooks, Jacks, and Slings
321 B30.25 2003 Scrap and Material Handlers Safety Standard for Cableways, Cranes, Derricks, Hoists, Hooks, Jacks, and Slings
322 B30.26 2004 Rigging Hardware
323 B30.27 2005 Material Placement Systems Safety Standard for Cableways, Cranes, Derricks, Hoists, Hooks, Jacks, and Slings
324 B30.3 2004 Tower Cranes
325 B30.3 INTERPRETATIONS 1996 Interpretations to B30.3-1996 Hammerhead Tower Cranes
326 B30.4 2003 Portal and Pedestal Cranes
327 B30.5 2004 Mobile and Locomotive Cranes
328 B30.5 INTERPRETATIONS 1993 Interpretations to B30.5-1994 Mobile and Locomotive Cranes
329 B30.6 2003 Derricks
330 B30.6 INTERPRETATIONS 2000 Interpretations to B30.6-2010 Derricks
331 B30.7 2006 Base Mounted Drum Hoists
332 B30.8 2004 Floating Cranes and Floating Derricks
333 B30.8 INTERPRETATIONS 1995 Interpretations to B30.8-1993 Floating Cranes and Floating Derricks
334 B30.9 2003 Slings
335 B30.9 INTERPRETATIONS 1997 Interpretations to B30.9-1996 Slings
336 B31.1 2010 Power Piping
337 B31.1 2004 Power piping
338 B31.1 INTERPRETATIONS 1997 Interpretations to B31.1-1998 Power Piping - Includes Interpretations No. 2 Through 6, 8 through 10, 13,15, 17 through 25, 27 through 31, and 42 through 44
339 B31.11 2002 Slurry Transportation Piping Systems
340 B31.2 1968 Fuel Gas Piping
341 B31.3 2004 Process Piping
342 B31.3 2008 Process Piping - Includes Interpretation 21
343 B31.3 2010 Process Piping- Includes Interpretation 22
344 B31.3 INTERPRETATIONS 2001 Interpretations to B31.3-1999 Process Piping - Includes Interpretations No. 1 Through 21
345 B31.4 2006 Pipeline Transportation Systems for Liquid Hydrocarbons and other Liquids
346 B31.4 INTERPRETATIONS 1997 Intrepretations to B31.4 Pipeline Transportation Systems for Liquid Hydrocarbons and Other Liquids - Includes Interpretations No. 5 and No. 8
347 B31.5 2006 Refrigeration Piping and Heat Transfer Components - Includes Interpretations Volume 8
348 B31.5 INTERPRETATIONS 1994 Interpretations to B31.5-1992 Refrigreration Piping - Includes Interpretation No. 1 Through 8
349 B31.8 2003 Gas Transmission and Distribution Piping Systems
350 B31.8 2010 Gas Transmission and Distribution Piping Systems
351 B31.8 INTERPRETATIONS 1999 Code for Pressure Piping
352 B31.8S 2004 Managing System Integrity of Gas Pipelines - Supplement to ASME B31.8
353 B31.9 2004 Building Services Piping
354 B31.9 INTERPRETATIONS 1997 Interpretations to B31.9-1996 Building Services Piping
355 B31G 2004 Manual for Determining the Remaining Strength of Corroded Pipelines
356 B31Q 2006 Pipeline Personnel Qualification
357 B32.100 2005 Preferred Metric Sizes for Flat, Round, Square, Rectangular, and Hexagonal Metal Products
358 B32.3M 1994 Preferred Metric Sizes for Flat Metal Products
359 B32.4M 1994 Preferred Metric Sizes for Round, Square, Rectangle and Hexagon Metal Products
360 B32.4M 1994 Preferred Metric Sizes for Round, Square, Rectangle and Hexagon Metal Products
361 B32.5 2004 Preferred Metric Sizes for Tubular Metal Products Other Than Pipe - Errata - 1996
362 B36.10M 2004 Welded and Seamless Wrought Steel Pipe
363 B36.19M 2004 Stainless Steel Pipe
364 B4.1 1994 Preferred Limits and Fits for Cylindrical Parts
365 B4.2 1994 Preferred Metric Limits and Fits
366 B4.3 1994 General Tolerances for Metric Dimensioned Products
367 B40.100 2005 Pressure Gauges and Gauge Attachments
368 B40.200 2001 Thermometers, Direct Reading and Remote Reading
369 B46.1 2002 Surface Texture (Surface Roughness, Waviness, and Lay)
370 B47.1 2004 Gage Blanks
371 B5.10 2002 Machine Tapers
372 B5.11 2002 Spindle Noses and Adjustable Adapters for Multiple Spindle Drilling Heads One of a Series of Standards for Small Tools and Machine Tool Elements
373 B5.18 2004 Spindle Noses and Tool Shanks for Milling Machines
374 B5.1M 2004 T-Slots, Their Bolts, Nuts, and Tongues - Revision of ANSI B5.1-1975
375 B5.35 2002 Machine Mounting Specifications for Abrasive Discs and Plate Mounted Wheels - Errata - October 1985
376 B5.40 2002 Spindle Noses and Tool Shanks for Horizontal Boring Machines
377 B5.47 2002 Milling Machine Arbor Assemblies
378 B5.48 2002 Ball Screws - Errata - March 1979
379 B5.49 2004 Glossary of power press terms
380 B5.50 2003 7/24 Taper Tool to Spindle Connection for Automatic Tool Change
381 B5.51M 2002 Preferred SI Units for machine toos
382 B5.52 2003 Power Presses: General Purpose, Single-Point Gap Type
383 B5.54 2005 Methods for Performance Evaluation of Computer Numerically Controlled Machining Centers - k
384 B5.55M 2002 Specification and Performance Standard, Power Press Brakes
385 B5.56M 2002 Specification and Performance Standard, Power Shears
386 B5.57 2006 Methods for Performance Evaluation of Computer Numerically Controlled Lathes and Turning Centers
387 B5.60 2002 Workholding Chucks: Jaw Type Chucks
388 B5.61 2004 Power Presses: General Purpose, Single Action, Straight Side Type
389 B5.8 2006 Chucks and Chuck Jaws
390 B5.9 2004 Spindle Noses for Tool Room Lathes, Engine Lathes, Turret Lathes, and Automatic Lathes
391 B73.1 2001 Specification for Horizontal End Suction Centrifugal Pumps for Chemical Process-Replaces B73.1M
392 B73.2 2003 Specification for Vertical In-Line Centrifugal Pumps for Chemical Process
393 B73.3 2003 Specification for Sealless Horizontal End Suction Metallic Centrifugal Pumps for Chemical Process
394 B73.5M 2001 Specification for Thermoplastic and Thermoset Polymer Material Horizontal End Suction Centrifugal Pumps for Chemical Process
395 B89.1.10M 2006 Dial Indicators (for Linear Measurements)
396 B89.1.13 2006 Micrometers
397 B89.1.17 2001 Measurement of Thread Measuring Wires
398 B89.1.17 ERTA 2006 Measurement of Thread Measuring Wires
399 B89.1.2M 1991 Calibration of Gage Blocks by Contact Comparison Methods (Through 20 in. and 500 mm)
400 B89.1.5 2004 Measurement of Plain External Diameters for Use as Master Discs or Cylindrical Plug Gages
401 B89.1.6 2002 Measurement of Plain Internal Diameters for Use as Master Rings and Ring Gages
402 B89.1.9 2002 GAGE BLOCKS - Incorporates Errata: December 2003
403 B89.3.1 2003 Measurement of Out-Of-Roundness
404 B89.3.4M 1992 Axes of Rotation: Methods for Specifying and Testing
405 B89.4.1 1997 Methods for Performance Evaluation of Coordinate Measuring Machines
406 B89.4.10 2006 Methods for Performance Evaluation of Coordinate Measuring Systems Software - Erratum September 2003
407 B89.4.19 2006 Performance Evaluation of Laser-Based Spherical Coordinate Measurement Systems
408 B89.4.22 2004 Methods for Performance Evaluation of Articulated Arm Coordinate Measuring Machines
409 B89.6.2 2003 Temperature and Humidity Environment for Dimensional Measurement
410 B89.7.2 2004 Dimensional Measurement Planning
411 B89.7.3.1 2006 Guidelines for Decision Rules: Considering Measurement Uncertainty in Determining Conformance to Specifications
412 B89.7.3.2 2007 Guidelines for the Evaluation of Dimensional Measurement Uncertainty
413 B89.7.3.3 2002 Guidelines for Assessing the Reliability of Dimensional Measurement Uncertainty Statements
414 B89.7.4.1 2005 Measurement Uncertainty and Conformance Testing: Risk Analysis
415 B89.7.5 2006 Metrological Traceability of Dimensional Measurements to the SI Unit of Length
416 B94.11M 1993 Twist Drills
417 B94.19 2003 Milling Cutters and End Mills
418 B94.2 2005 Reamers
419 B94.21 2003 Gear Shaper Cutters
420 B94.33 2005 Jig Bushings
421 B94.33.1 2005 Jig Bushings (Metric)
422 B94.35 2005 Drill Drivers, Split-Sleeve, Collet Type
423 B94.37M 1985 Roller Turner Type Cutting Tools, Single Point - Revision of B94.37-1972
424 B94.49 2005 Spade Drill Blades and Spade Drill Holders
425 B94.51M 2005 Specifications for Band Saw Blades (Metal Cutting)
426 B94.52M 2005 Specifications for ****saw Blades
427 B94.53 1984 Solid Steel Rectangular Metal Cutting Squaring Shear Knives Dimensional Tolerances
428 B94.54 2005 Specifications for Hole Saws, Hole Saw Arbors, and Hole Saw Accessories
429 B94.55M 2003 Tool Life Testing with Single-Point Turning Tools
430 B94.6 2003 Knurling
431 B94.7 2005 Hobs
432 B94.9 1999 Taps: Ground Thread With Cut Thread Appendix (Inch and Metric Sizes)
433 BPE 2005 Bioprocessing Equipment
434 BTH-1 2005 Design of Below-the-Hook Lifting Devices
435 CSD-1 2006 Controls and Safety Devices for Automatically Fired Boilers
436 CSD-1 INTERPRETATIONS 2006 Interpretations to CSD-1 Controls and Safety Devices for Automatically Fired Boilers - Includes Interpretations Dated February 1989 Through October 2001, Volume 13, Volume 14
437 HPS 2003 High Pressure Systems
438 HST-1 2004 Performance Standard for Electric Chain Hoists
439 HST-2 2004 Performance Standard for Hand Chain Manually Operated Chain Hoists
440 HST-3 2004 Performance Standard for Hand Chain Manually Operated Chain Hoists
441 HST-4 2004 Performance Standard for Hand Chain Manually Operated Chain Hoists
442 HST-5 2004 Performance Standard for Air Chain Hoists
443 HST-6 2004 Performance Standard for Air Wire Rope Hoists
444 MFC-10M 2006 Method for Establishing Installation Effects on Flowmeters
445 MFC-11 2006 Measurement of Fluid Flow by Means of Coriolis Mass Flowmeters
446 MFC-12M 2006 Measurement of Fluid Flow in Closed Conduits Using Multiport Averaging Pitot Primary Elements
447 MFC-13M 2006 Measurement of Fluid Flow in Closed Conduits: Tracer Methods
448 MFC-14M 2003 Measurement of Fluid Flow Using Small Bore Precision Orifice Meters
449 MFC-16M 2006 Measurement of Liquid Flow in Closed Conduits With Electromagnetic Flowmeters
450 MFC-18M 2006 Measurement of Liquid Flow in Closed Conduits With Electromagnetic Flowmeters
451 MFC-1M 2003 Glossary of Terms Used in the Measurement of Fluid Flow in Pipes
452 MFC-2M 2006 Measurement Uncertainty for Fluid Flow in Closed Conduits
453 MFC-3M 2004 Measurement of Fluid Flow in Pipes Using Orifice, Nozzle, and Venturi
454 MFC-4M 2003 Measurement of Gas Flow by Turbine Meters
455 MFC-5M 2006 Measurement of Liquid Flow in Closed Conduits Using Transit-Time Ultrasonic Flowmeters
456 MFC-6M 2005 Measurement of Fluid Flow in Pipes Using Vortex Flowmeters
457 MFC-7M 2006 Measurement of Gas Flow by Means of Critical Flow Venturi Nozzles
458 MFC-8M 2006 Fluid Flow in Closed Conduits : Connections for Pressure Signal Transmissions Between Primary and Secondary Devices
459 MFC-9M 2006 Measurement of Liquid Flow in Closed Conduits by Weighing Methods
460 N278.1 1992 Self-Operated and Power-Operated Safety-Related Valves Functional Specification Standard, Reactor Plants and Their Maintenance
461 N509 2002 Nuclear Power Plant Air-Cleaning Units and Components
462 N509 INTERPRETATIONS 1992 Interpretations to N509-1989 Nuclear Power Plant Air-Cleaning Units and Components
463 N510 1995 Testing of Nuclear Air Treatment Systems
464 NOG-1 2004 Rules for Construction of Overhead and Gantry Cranes (Top Running Bridge, Multiple Girder)
465 NQA TECH REPT 1993 Comparison of ASME NQA-1 and ISO 9001
466 NQA-1 2008 Quality Assurance Requirements for Nuclear Facility Applications
467 NQA-1 2004 Quality Assurance Requirements for Nuclear Facility Applications
468 NQA-1 INTERPRETAT 2010 ASME NQA-1 INTERPRETAT_2010
469 NQA-1 INTERPRETATIONS 2001 Interpretations to NQA-1 Quality Assurance Requirements for Nuclear Facility Applications
470 NUM-1 2004 Rules for Construction of Cranes, Monorails, and Hoists (With Bridge or Trolley or Hoist of the Underhung Type)
471 OM CODE 2004 Operation and Maintenance of Nuclear Power Plants
472 OM CODE CASES 2003 Code Cases to OM CODE Code for Operation and Maintenance of Nuclear Power Plants
473 OM CODE INTERPRETATIONS 1998 Code Cases to OM CODE Code for Operation and Maintenance of Nuclear Power Plants
474 PALD 2005 Safety Standard for Portable Automotive Lifting Devices
475 PALD INTERPRETATIONS 1997 Interpretations to PALD-1997 Safety Standard for Portable Automotive Lifting Devices
476 PCC-1 2000 Guidelines for Pressure Boundary Bolted Flange Joint Assembly
477 PCC-2 2006 Repair of pressure equipment and piping
478 PTB-1 2009 Section VIII ?Division 2 Criteria and Commentary
479 PTC 31 2011 High-Purity Water Treatment Systems
480 PTC PM 1993 Performance Monitoring Guidelines for Steam Power Plants
481 PTC1 2004 General Instructions
482 PTC10 2003 Performance Test Code on Compressors and Exhausters
483 PTC11 2003 Fans
484 PTC12.1 2005 Closed Feedwater Heaters
485 PTC12.2 2007 Performance Test Code on Steam Surface Condensers
486 PTC12.3 2004 Performance Test Code on Deaerators
487 PTC12.4 2004 Moisture Separator Reheaters
488 PTC12.5 2005 Single Phase Heat Exchangers
489 PTC17 2003 Reciprocating Internal-Combustion Engines
490 PTC18 2002 Hydraulic Turbines and Pump-Turbines-Consolidation of ASME PTC 18-1992 and ASME PTC 18.1-1978
491 PTC19.1 2005 Flow Measurement
492 PTC19.10 1981 Part 10: Flue and Exhaust Gas Analyses Instruments and Apparatus
493 PTC19.11 2004 Steam and Water Sampling, Conditioning, and Analysis in the Power Cycle
494 PTC19.2 2004 Part 2: Pressure Measurement Instruments and Apparatus
495 PTC19.22 1998 Data Acquisition Systems
496 PTC19.23 1985 Part 23: Guidance Manual for Model Testing Instruments and Apparatus
497 PTC19.3 2004 Part 3: Temperature Measurement Instruments and Apparatus
498 PTC19.5 2004 Flow Measurement
499 PTC19.7 1988 Part 7: Measurement of Shaft Power Instruments and Apparatus
500 PTC2 2001 Definitions and Values Performance Test Codes
501 PTC22 2005 Performance Test Code on Gas Turbines
502 PTC23 2003 Atmospheric Water Cooling Equipment
503 PTC24 1982 Ejectors
504 PTC25 1998 Pressure Relief Devices
505 PTC25 2001 Pressure Relief Devices
506 PTC28 1985 Determining the Properties of Fine Particulate Matter
507 PTC29 2005 Speed-Governing Systems for Hydraulic Turbine-Generator Units
508 PTC30 1998 Air Cooled Heat Exchangers
509 PTC30.1 2007 Air-Cooled Steam Condensers
510 PTC36 2004 Measurement of Industrial Sound
511 PTC38 1985 Determining the Concentration of Particulate Matter in a Gas Stream
512 PTC39 2005 Steam Traps
513 PTC4 1998 Fired Steam Generators
514 PTC4 2008 Fired Steam Generators
515 PTC4.2 2003 Coal Pulverizers
516 PTC4.3 1991 Air Heaters
517 PTC4.4 2003 Gas Turbine Heat Recovery Steam Generators
518 PTC40 1991 Flue Gas Desulfurization Units
519 PTC42 2004 Wind Turbines
520 PTC46 1996 Performance Test Code on Overall Plant Performance
521 PTC47 2007 Integrated Gasification Combined Cycle Power Generation Plants
522 PTC50 2002 Fuel Cell Power Systems Performance
523 PTC6 2004 Steam Turbines-Erratum
524 PTC6 REPORT 1997 Guidance for Evaluation of Measurement Uncertainty in Performance Tests of Steam Turbines
525 PTC6.2 2005 Steam Turbines in Combined Cycles
526 PTC6A 2000 Appendix A To PTC 6, the Test Code for Steam Turbines
527 PTC6S REPORT 2003 Procedures for Routine Performance Tests of Steam Turbines
528 PTC8.2 1991 Centrifugal Pumps
529 PVHO-1 2002 Safety Standard for Pressure Vessels for Human Occupancy
530 PVHO-2 2003 Safety Standard for Pressure Vessels for Human Occupancy In-Service Guidelines for PVHO Acrylic Windows
531 QAI-1 2005 Qualifications for Authorized Inspection
532 QAI-1 INTERPRETATIONS 1996 Interpretations to QAI-1-1995 Qualifications for Authorized Inspection
533 QEI-1 2004 Standard for the Qualification of Elevator Inspectors
534 QFO-1 1998 Standard for the Qualification and Certification of Operators of High Capacity Fossil Fuel Fired Plants
535 QHO-1 2004 STANDARD FOR THE QUALIFICATION AND CERTIFICATION OF HAZARDOUS WASTE INCINERATOR OPERATORS
536 QME-1 2002 Qualification of Active Mechanical Equipment Used in Nuclear Power Plants
537 QMO-1 2000 Qualification and Certification of Medical Waste Incinerator Operators
538 QRO-1 2005 Standard for the Qualification and Certification of Resource Recovery Facility Operators
539 RA-S 2002 Standard for Level 1/Large Early Release Frequency Probabilistic Risk Assessment for Nuclear Power Plant Applications - Includes Interpretations Volume 1
540 RTP-1 2007 Reinforced Thermoset Plastic Corrosion-Resistant Equipment
541 RTP-1 2005 Reinforced Thermoset Plastic Corrosion-Resistant Equipment
542 RTP-1 INTERPRETATIONS 1998 Interpretations to RTP-1 Reinforced Thermoset Plastic Corrosion-Resistant Equipment - Includes Interpretations January 1989 to July 2002
543 SA370 Test methods and definitions for mechanical testing of steel products
544 SI-1 1982 Orientation and Guide for Use of SI (Metric) Units
545 STS-1 2006 Steel stack
546 TDP-1 1998 Recommended Practices for the Prevention of Water Damage to Steam Turbines Used for Electric Power Generation Fossil-Fueled Plants
547 TDP-1 2006 Recommended Practices for the Prevention of Water Damage to Steam Turbines Used for Electric Power Generation Fossil-Fueled Plants
548 Y14.1 2005 Decimal Inch Drawing Sheet Size and Format
549 Y14.100 2004 Engineering Drawing Practices
550 Y14.1M 2005 Metric Drawing Sheet Size and Format
551 Y14.24 2004 Types and Applications of Engineering Drawings - Revision of ASME Y14.24M-1989
552 Y14.2M 2003 Line Conventions and Lettering
553 Y14.3 2003 Multiview and Sectional View Drawings
554 Y14.32.1M 1999 Chassis Frames - Passenger Car and Light Truck - Ground Vechicle Practices
555 Y14.34M 2002 Associated Lists
556 Y14.35M 2003 Revision of Engineering Drawings and Associated Documents
557 Y14.36M 2002 Surface Texture Symbols
558 Y14.38 2006 Abbreviations and Acronyms for Use on Drawings and Related Documents
559 Y14.41 2003 Digital Product Definition Data Practices
560 Y14.42 2002 Digital Approval Systems
561 Y14.43 2003 Dimensioning and Tolerancing Principles for Gages and Fixtures
562 Y14.4M 2005 Pictorial Drawing
563 Y14.5.1M 2004 Mathematical Definition of Dimensioning and Tolerancing Principles
564 Y14.5.2 2000 Certification of Geometric Dimensioning and Tolerancing Professionals
565 Y14.5M 2004 Dimensioning and Tolerancing
566 Y14.6 2007 Screw Thread Representation
567 Y14.8M 2002 Castings and Forgings
568 Y32.18 2003 Symbols for Mechanical and Acoustical Elements as Used in Schematic Diagrams
569 Y32.7 2004 Graphic Symbols for Railroad Maps and Profiles
