Thread: Book---Offshore Engineering and Production needed
    Foreword
    The Author
    Preface
    Acknowledgements
    Abbreviations
    Glossary
    Standards, Guidance Notes and Codes of Practice
    1 Introduction and Background
    1.1 Worldwide Oil and Gas Production – Perspective
    1.2 Field Developments – Field Size
    1.3 Reserves
    1.4 Oil and Gas Prices
    2 Offshore Structures and Support Vessels
    2.1 Offshore Structures
    2.1.1 Fixed Steel Structures
    2.1.2 Concrete Gravity Base Structure (GBS)
    2.1.3 Tension Leg Platform (TLP)
    2.1.4 Semi-Submersible Vessel (Semi-Sub)
    2.1.5 Floating Production Systems (FPS)
    2.1.6 Self-Elevating Jack-Up
    2.1.7 Single Point Mooring (SPM)
    2.2 Support Vessels
    2.2.1 The Offshore Supply Boat
    2.2.2 Standby Vessels
    2.3 Offshore Installation Descriptions
    2.4 Fixed Steel Structures – Installation
    2.4.1 Construction
    2.4.2 Load Out and Transportation
    2.4.3 Installation
    2.4.4 Piling Operations
    2.4.5 Topside Installation
    2.4.6 Abandonment
    2.4.7 RWE DEA UK ‘Cavendish’ Installation
    3 Safety Systems
    3.1 Fire-Fighting Equipment
    3.1.1 Equipment Approval
    3.1.2 Guidance Notes and Standards
    3.1.3 Active Fire Protection
    3.1.4 Portable Fire-Fighting Equipment
    3.1.5 Helideck Fire-Fighting Equipment
    3.1.6 Remote Stops and Closing Devices
    3.2 Passive Fire Protection
    3.2.1 Fire Divisions – Designations
    3.2.2 Fire Divisions – Penetrations
    3.2.3 Draught Stops
    3.2.4 Furnishings
    3.2.5 New Developments
    3.3 Life-Saving Appliances
    3.3.1 Life-Saving Equipment
    3.3.2 Lifeboats
    3.3.3 Liferafts
    3.3.4 Descent Devices
    3.3.5 Lifejackets and Personal Survival Equipment
    3.3.6 Lifebuoys
    3.3.7 Maintenance
    3.4 Navigational Aids – Fixed Offshore Installations
    3.4.1 Visual Navigation Aids
    3.4.2 Audible Navigational Aids
    3.4.3 Navigation Aids Failure
    3.4.4 Helideck Illumination
    3.4.5 Identification Panels
    3.5 Hazardous Areas
    3.5.1 Hazardous Areas and their Determination
    3.5.2 Ventilation Systems and Machinery in Hazardous Areas
    3.5.3 Hazardous Area Equipment
    3.6 Emergency Systems
    3.6.1 Emergency Shutdown System (ESD)
    3.6.2 Process ESD Valves
    3.6.3 Gas Detection
    3.6.4 Fire Detection
    3.6.5 Containment Systems
    3.6.6 Fire Loop
    3.6.7 Emergency Shutdown Valves – Pipelines
    3.6.8 Guidance Notes and Reference Standards
    3.7 Deepwater Horizon – Impact for the Industry
    3.7.1 Background
    3.7.2 The National Commission on the BP Deepwater Horizon
    Oil Spill and Offshore Drilling
    3.7.3 The Events Leading up to the Incident
    3.7.4 Analysis of the Incident
    3.7.5 The First Changes After the Incident
    4 Piping Systems and Process Pressure Vessels
    4.1 Piping Systems
    4.1.1 Hydrocarbon Process
    4.1.2 Utility Systems
    4.2 Process Pressure Vessels
    4.2.1 Gas/Oil (Condensate)/Water Separators
    4.2.2 Gas/Liquid Separators
    4.2.3 Oil/Water Separators
    4.2.4 Holding Tanks
    4.3 Piping and Pressure Vessel Design
    4.3.1 Piping Systems – Installation and Layout
    4.3.2 Piping Systems – Design
    4.3.3 Pipeline System – Design
    4.3.4 Pressure Vessels – Design
    4.4 Piping Systems – Construction
    4.4.1 Piping Classes
    4.4.2 Pipe Materials
    4.4.3 Fittings
    4.4.4 Valves
    4.4.5 Bolting
    4.4.6 Pressure Testing
    4.4.7 Pipeline Testing
    4.4.8 Golden Welds
    4.4.9 Pipeline Commissioning
    5 Oil and Gas Production
    5.1 Gas Production
    5.1.1 Wellheads
    5.1.2 Slug Catcher
    5.1.3 Meter Run and Test Separator
    5.1.4 Production Header
    5.1.5 Production Separator
    5.1.6 Heat Exchanger
    5.1.7 Glycol Contactor (or Absorption Tower)
    5.1.8 Discharge Header
    5.1.9 Export Line
    5.1.10 The Liquid Process
    5.2 Oil Production
    5.2.1 The Oil Process
    5.2.2 Improvement in Oil Production
    5.2.3 Associated Gas
    5.3 Enhanced Oil Recovery and the Oil Drive Mechanism
    5.3.1 The Oil Drive Mechanism
    5.3.2 Enhanced Oil Recovery Systems
    5.3.3 Water Injection
    5.3.4 Minox De-Oxygenation System
    5.3.5 Gas Injection
    5.3.6 Gas Lift
    5.3.7 The Deepwell/Submergible Pump
    6 Underwater Engineering
    6.1 Diving
    6.1.1 Air Diving
    6.1.2 Saturation Diving
    6.1.3 Equipment
    6.1.4 Vessels
    6.2 Underwater Surveys
    6.2.1 Splash Zone Visual Inspection
    6.2.2 Swimaround Survey
    6.2.3 Non-Destructive Examination
    6.2.4 Flooded Member Survey
    6.2.5 Marine Growth Measurement
    6.2.6 Scour Survey
    6.2.7 Cathodic Protection Examination
    6.2.8 Differential Settlement Survey
    6.2.9 Air Gap Measurement
    6.3 Subsea Wells
    6.3.1 Subsea Development Options
    6.3.2 Subsea Wells
    6.4 Subsea Developments
    6.4.1 Subsea Separation
    6.4.2 Multiphase Pumping and Metering
    7 Drilling
    7.1 Introduction
    7.1.1 The Formation of Oil and Gas
    7.1.2 Exploration
    7.2 The Well
    7.2.1 Well Construction
    7.2.2 The Cement Job
    7.3 Equipment
    7.3.1 Drilling Derrick
    7.3.2 The Drill String
    7.3.3 Drilling Mud
    7.4 Operations
    7.4.1 The Drill Crew
    7.4.2 Making Hole
    7.5 Well Control Equipment
    7.5.1 The Diverter
    7.5.2 The Blowout Preventer
    7.5.3 BOP Operations
    7.6 Drill Ship Equipment
    7.7 Deviated Wells
    7.7.1 Directional Drilling Techniques
    7.7.2 Horizontal Wells
    7.7.3 Geosteering
    7.7.4 Multi-Lateral Wells
    8 Component Parts
    8.1 The Christmas Tree
    8.1.1 Solid Block Christmas Tree
    8.1.2 Wellhead Control Panel
    8.1.3 Gate Valves and Actuators
    8.1.4 Horizontal Trees
    8.2 The Surface Wellhead
    8.2.1 Base Plate/Landing Ring
    8.2.2 Starting Head
    8.2.3 Casing Head Spools
    8.2.4 Tubing Head Spool
    8.2.5 Christmas Tree
    8.3 Mudline Suspension Systems – (MLSS)
    8.3.1 Pre-Drilling of Wells
    8.3.2 Subsea Wells
    8.4 Mudline Safety Valve
    8.5 The Production Packer
    9 Well Maintenance
    9.1 Wireline Operations
    9.1.1 Wireline Equipment
    9.1.2 Wireline Tool String
    9.1.3 Wireline Operations
    9.2 Workover Operations
    9.2.1 Well Stimulation
    9.2.2 Well Modifications
    Appendices
    Appendix I – Structural Steel
    Appendix II – Welding
    Appendix III – Non-Destructive Examination
    Appendix IV – Units of Measurements
    Appendix V – Table of Line Pipe Dimensions
    Appendix VI – UK Legislation
    Index
  3. Cool Re: Book---Offshore Engineering and Production needed
    [QUOTE=gmarshall;245558]Foreword
    The Author
    Preface
    Acknowledgements
    Abbreviations
    Glossary
    1.3 Reserves
    2.2 Support Vessels
    2.4.1 Construction
    2.4.3 Installation
    2.4.6 Abandonment
    3 Safety Systems
    3.2.3 Draught Stops
    3.2.4 Furnishings
    3.3.2 Lifeboats
    3.3.3 Liferafts
    3.3.6 Lifebuoys
    3.3.7 Maintenance
    3.5 Hazardous Areas
    3.6.3 Gas Detection
    3.6.6 Fire Loop
    3.7.1 Background
    4.1 Piping Systems
    4.2.4 Holding Tanks
    4.4.3 Fittings
    4.4.4 Valves
    4.4.5 Bolting
    4.4.8 Golden Welds
    5.1 Gas Production
    5.1.1 Wellheads
    5.1.2 Slug Catcher
    5.1.9 Export Line
    5.2 Oil Production
    5.3.5 Gas Injection
    5.3.6 Gas Lift
    6.1 Diving
    6.1.1 Air Diving
    6.1.3 Equipment
    6.1.4 Vessels
    6.2.6 Scour Survey
    6.3 Subsea Wells
    6.3.2 Subsea Wells
    7 Drilling
    7.1 Introduction
    7.1.2 Exploration
    7.2 The Well
    7.3 Equipment
    7.3.3 Drilling Mud
    7.4 Operations
    7.4.2 Making Hole
    7.5.1 The Diverter
    7.7 Deviated Wells
    7.7.3 Geosteering
    8 Component Parts
    8.2.2 Starting Head
    8.3.2 Subsea Wells
    9 Well Maintenance
    Appendices
    Index[/QUOte
    Where is the download link ?
  5. Re: Book---Offshore Engineering and Production needed
    it seems good.... who may share it ?
  1. Drilling Engineering Book Needed
    By zahid_sunny in forum Drilling And Workover
    Last Post: 02-21-2014, 10:25 AM
  2. Drilling Engineering Book Needed
    By mridul in forum Drilling And Workover
    Last Post: 01-26-2014, 11:24 PM
  3. Offshore Multiphase Production Operations
    By Mohamed in forum Oil And Gas Production
    Last Post: 12-19-2013, 12:07 AM
  4. Offshore Production & Subsea Production
    Last Post: 03-26-2011, 09:09 PM
  5. reservoir engineering book needed urgently
    By orbawy in forum Reservoir
    Last Post: 06-26-2010, 06:32 PM
